Go to Post Don't short change your drivers. They really need drive time. - Joe Johnson [more]
Unread 13-01-2011, 23:48
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
Replacing the classmate?
The classmate we used last year is pretty much broken due to several team members yanking on the ethernet cables, so we decided to scrap the classmate, and get a real netbook to compete with in competitions (allowed due to <R75>)
<R75>The Driver Station software provided on the FRC website (www.usfirst.org/frc/kitofparts) is the only tool permitted to collate driver/operator inputs and communicate them to the ROBOT. The Driver Station software must be revision 01.05.11.00 or newer.
Teams are permitted to use a portable computing device of their choice (laptop computer, PDAs, etc.) to host the Driver Station software while participating in competition MATCHES.
However, I recall (from kickoff) that if teams use another portable computing device, they would need to contact first to get a special update to flash or to install the driver station. I tried finding this link in the rule book, and on the first site, but I can't seem to find it.
Has anyone else found (or know) where I could find this page to contact FIRST for the updates for my new netbook (Dell Mini 1018)? Or would I just have to download the driver station from here: http://usfirst.org/WorkArea/linkit.a...d&ItemID=18758 ?
Team 1403 Cougar Robotics
2009-2011 Programming Captain
2010
NJ-Regional - Chairmans Award
Unread 14-01-2011, 00:29
Re: Replacing the classmate?
I think the "contact FIRST" advice was specifically for veteran teams who purchase a new Classmate matching the one in this year's Rookie kit.
Unread 14-01-2011, 09:34
Programming Captain
AKA: Umang
Ahh, thank you!
2010
Unread 14-01-2011, 10:43
Here's what NI says to install to run the driver station on another computer: http://decibel.ni.com/content/thread/8794?tstart=0
Unread 28-01-2011, 16:59
cgvanguard cgvanguard is offline
FRC #3261
cgvanguard is an unknown quantity at this point
Question Re: Replacing the classmate?
We are having problems with our 2010 Classmate - and may want to get a netbook instead. The Classmate SAYS it has a 16 GB harddrive - but, when imaged with the FIRST flashdrive - it sets up as a 10 GB - which leaves very little room to work.
Anyone have a solution or have instructions for setting up a netbook instead?
Also - Do we need to use Windows 7 or is XP OK?
Unread 28-01-2011, 17:57
You can regain the missing 5GBYou can leave it as XP or upgrade to Win 7
Unread 07-02-2011, 00:44
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
The images (supplied on the USB flash drives in the KOP) are only for updating the two Classmate models that were issued in the KOP over the past two years. You do not want to try to use them on any other computer!
Almost any laptop can run the driver station and be used as a replacement for the Classmate. We do it all the time with our development computers. (Dell and Toshiba laptops running XP and Win 7)
You want to be sure to do the updates that install the latest Driver Station. (and any future ones) You'll probably want to install this year's LabView, the updates, and utilities. It'll take an hour or two.
Use the version of Windows that you have. If you're buying a new computer, it will probably be some version of Win 7, and should work fine with that. Vista and XP should do as well. Be sure all service packs have been installed.
To make the computer, such as a netbook, work like the Classmate did, create a user account and name it Driver. Then put a shortcut to the FRC Driver Station in the Startup folder in that user's account. When it boots into that account, the Driver Station and Dashboard will open and tile just like on the Classmate. If the screen size is similar, it should look the same too. Exiting the Driver station will log out of the account just like the Classmate did too.
I've done this on my Acer One netbook, running XP, and it works just fine. It'll make a backup just in case.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
