Go to Post Being inspired is a lot like learning, not everybody does it the same way. - Jay Trzaskos [more]
Unread 14-01-2011, 10:28
MaxKinect MaxKinect is offline
FRC #0494
MaxKinect is an unknown quantity at this point
Kinect is Legal for Both Drive Station and Field Use (Here’s why)
Team 494 (Bill Maxwell/Martians) has been working with Kinect since its introduction
One Handed Kinect FPS Hack - Better Than Mouse
http://www.youtube.com/watch?v=1j9UhxtmWmA
This is a device driver that is designed to replace a controller.
It will work on the drive station and provide joystick info to the driver station program which will be sent to the crio. Extra information can also be sent through the drive station sensor information packet field.
The minimum distance the sensor will work is 17 inches; therefore the sensor must be elevated above the drive station pointed downward.
This means that only the drivers can control the robot using the kinect. During autonomous the driver’s arms are not visible to the elevated Kinect. This makes the kinect legal for the drive station.
The Kinect looking downward (maybe on a simple pole) give very high resolution depth information of the driver’s arms. Think of all the possible virtual controls that could be printed flat on your drive station control board.
Field use is possible, but might have some problems.
First the sensor is super safe in its light output, 8 million units have been sold to be used by children standing in front and looking straight at sensor.
A laptop can be used on the robot, the kinect sensor is connected to the usb port on the laptop, its extra 12volts can be supplied by the robot battery.
It is very legal to connect a laptop to the crio's network port.
This gives you unlimited programming possibilities.
Now for the field use problems:
Based on our test the sensor will work to about 28 feet in low light.
If the sensor is moved outside into the sunlight its range drops to less than 4 feet.
Different events will have different lighting, how much this will affect the kinect is unknown, and any modification of the kinect light output would make its safety unknown and therefore very illegal.
The next problem is that multiple Kinects used on the field could interfere with each other. People testing this find the interference low with 3 units, but what if everyone on the field is using kinect?
The final problem is that FIRST may just say NO.
I hope everyone will work toward making depth sensors standard for FIRST, because they are the future of robotics.
Unread 14-01-2011, 10:41
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: Kinect is Legal for Both Drive Station and Field Use (Here’s why)
I'm not up-to-speed on the whole 'Kinect' thing, but doesn't it have some sort of laser? I think that's the FIRST-illegal part.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 14-01-2011, 10:44
smileydude560 smileydude560 is offline
He who cannot write.
AKA: Tyler
FRC #2910 (Jack in the Bot)
Team Role: Student
smileydude560 is an unknown quantity at this point
http://gizmodo.com/5701466/kinect-3d...en-more-insane
Here's an example of two Kinects working together, the poster commented on the distortion. Sorry for the indirect link, no youtube at school.
Unread 14-01-2011, 10:57
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
It sends a bunch of IR dots (normal light, not lasers) all over the room that it is being used in, and uses an IR camera to detect the reflected position and intensity of each dot to determine the depth.
http://en.wikipedia.org/wiki/Structu...ght_3D_Scanner
Unread 14-01-2011, 11:15
Originally Posted by Bongle View Post
It sends a bunch of IR dots (normal light, not lasers)...
The Kinect depth sensor uses an IR laser to generate those dots. That runs afoul of the FRC robot rules.
Unread 14-01-2011, 11:24
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If a non-reflective surface were put on the driver's station, and the Kinect pointed down at that surface, I don't think that the GDC would disallow a Kinect due to safety within that context. If a driver can manipulate the robot that way, more power to him/her! Actually, you could probably put a proper-scale representation of the robot under the Kinect and manipulate it to manipulate the robot (like 1731 did in 2007 -- see the Behind the Design book).
As for use on the live robot, I think that there are still too many unknowns. If anything, Q&A it with very specific parameters in mind. If it's approved and you stay within those parameters, you would have a very strong argument (but not a guarantee since the inspectors have the final say in anything contextual) that the Kinect is safe for use.
GitHub
Unread 14-01-2011, 11:27
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
This would be a good question for the GDC. Because of the type of low power IR laser you may get an exception.
Unread 14-01-2011, 12:56
FRC #0494
I check my Kinect and found it to have a Class 1 safty rating
http://en.wikipedia.org/wiki/Laser_safety#Class_1
Class 1 LASER PRODUCT
A class 1 laser is safe under all conditions of normal use.
I will ask the GDC.
But just in case there is a problem,
I checked on the Kinect IR Emitter and found to run at the same frequency as tv remotes 830nm with a static image generated by a 30000 point caustic patterend grate. Would it be possible to replace the Kinect IR Emitter with a standard IR led of the same power ratting. FIRST uses IR leds everwhere.
What do you think?
Unread 14-01-2011, 14:13
Bongle's Avatar
Interesting. I (obviously) had no idea. I had seen the IR-camera youtube videos and remembered the dots being so big that I figured they were generated via a non-laser IR emitter somehow.
Edit: Now having re-watched the videos, it makes a lot more sense that it's a laser.
Unread 14-01-2011, 15:20
No. An incoherent light source would not work with the pattern grating. It must be a laser.
(Perhaps a "QWLED" device that I remember reading about a couple of decades ago would work. It produced coherent but highly divergent light, suitable for tabletop holography. I never heard about it again, so perhaps it never made it to an actual product.)
Unread 14-01-2011, 15:32
I will ask the GDC.
When you ask, you may want to differentiate between use on the ROBOT and use on the OPERATOR CONSOLE.
Unread 14-01-2011, 18:16
Ryan Gordon Ryan Gordon is offline
FRC #2854 (EVHS Robotics)
Ryan Gordon is an unknown quantity at this point
Even if it is legal, it shouldn't be. Too many Kinect's on the field could definitely cause too much interference and unexpected results. The Kinect operates on a 830nm wavelength (near the wavelength of a laser mouse) uniformly across ALL Kinect's manufactured so therefore if at any point during the match if the 830nm projections are projected onto other projections or if projections are projected on top of other projections there will be interference. The more Kinect's in one area, the higher the chance of interference. There are also other things to worry about such as IR-absorbent material on the field and such, not even to mention the difficulties you will have in getting the Kinect to work through the cRIO.
All the information you will ever want: http://openkinect.org/wiki/Hardware_info
Unread 14-01-2011, 22:19
FRC #0494
Because the Kinect controller uses a pattern match on a non-repeating caustic pattern it is very resistant to interference. When there is a problem, the area of the problem is marked with a 'unknown' depth code (2047).
When we use a standard light camera there are hundreds of interference artifacts each frame that must be filtered out, this is not needed with the kinect.
We have tried to use sonar sensors in the past, but everything interferes with them.
Our testing so far has found only mirrors to be a problem. Carpet, the logo tubes and other robots (we have lots of them) image very well.
This is no problem at all; we can use laptops on our robots this year. Kinect runs very well in both windows 7 and XP. We also can connect the laptop to the crio's second network port.
This is my seventh year as mentor in FIRST, this is the first time it is possible to use leading edge tech in our robot. We may not make it to the field because of FIRST stopping up, but we will not stop trying to make the best robot possible. We will be able to use our new tech in off season competitions and most importantly demonstrations to new students and sponsors.
This is the begining of new age, the natural computer (robot) interface.
Unread 14-01-2011, 22:57
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Oh, what would be the advantage of a kinect over a regular old joystick?
Oh and good luck with autonomy with a kinect. Have fun trying to communicate with the cRio efficiently enough so that you can rotate the Kinect and not sacrifice precious clock cycles.
Unread 15-01-2011, 08:37
FRC #0494
This is a very good question.
We will program our drive station to use both a XBOX controller and the Kinect. (Not at the same time) Based on years of using a joystick (Xbox controller) we know how it works. The Kinect interface will be a totally new adventure. Our goal will be to make a natural interface in which anyone can walk up and drive our robot. This may not be possible in 5 weeks, it may never be possible.
The kinect on the field may not be a good choice for this game. We will find out by trying both a standard camera and the Kinect (depth sensor).
As for the cRio precious clock cycle, if we off load the visual processing to a laptop and use C++ in the cRio there will be lots of unused cRio cycles.
