Go to Post Great teams with great software have control loops. Clever teams without software have pneumatics. - Chris is me [more]
Unread 13-01-2011, 14:39
nick_champ_2 nick_champ_2 is offline
AKA: Nick Reed
FRC #2902 (Nyack)
nick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the rough
Send a message via Yahoo to nick_champ_2
Thumbs up IF NEEDING HELP POST HERE!
Hello From F.I.R.S.T. FTC team 3755 / F.I.R.S.T FRC Team 2902
We are extending our hands in helping teams with issues they are having with programing and general issues. I, personally, am a computer technician and can help with the programming and general computer issues, as well as networking issues. Though we are extending our hand to all issues. We have the ability to do a video confrence with teams so that you can see what we are talking about vs. just get an idea of it.
If you need help get in contact with us!
Soon we will start a new webpage with video updates to help teams as this year is going to be a difficult year.
Happy Building!
F.I.R.S.T. FRC Team 2902
Unread 13-01-2011, 15:05
J-Mech's Avatar
J-Mech J-Mech is offline
FRC #1361
J-Mech is an unknown quantity at this point
Angry Re: IF NEEDING HELP POST HERE!
Hello,
Thanks for putting this post up. Our team is having trouble connecting to the cRIO. We have tried reformatting it and reinstalling both Wind River and LabVIEW several times. We can ping the cRIO; however, when we go to connect to it or build and place code onto it the programs will not connect. We do have the latest images and updates as far as we can tell. The error we get most often is that it failed to launch the target server. Do you know of any reasons this may be happening? Everything is wired correctly according to the diagram.
Thanks in advance for your time.
Unread 13-01-2011, 15:10
AKA: Nick Reed
FRC #2902 (Nyack)
Just the basics I figured you have covered but still have to verify. Do you have your up address set in the crio, the computer, and how do you have the items connected.
Unread 13-01-2011, 15:12
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
I would try connecting the cRIO with a crossover to your development computer and try to connect from there. I would make the IP settings on your computer 10.xx.yy.7, 255.0.0.0 and 10.xx.yy.2
Is your classmate able to see "Communications" from the Driver Mode?
What is the RSL pattern? That could give some information too.
This is from last year's documentation, but I assume* it is the same.
Solid ON = Autonomous Enabled
Solid ON, but blinks OFF every 1.5s = Teleoperated Enabled
Slow Blink (900ms on / 900ms off) = System disabled; caused by system watchdog, user
watchdog, or Driver’s Station set to Disabled.
Fast-Slow Blink (200ms on / 900ms off) = Low battery (<12 Volts) or no user code and system disabled either by system watchdog, user watchdog, or Drivers’s Station set to Disabled.
Fast Blink (200ms on / 200ms off) = System error: No Driver’s Station communication, bad cRIO Image, bad team ID, extensive communication errors. (I assume it's this one).
Unread 13-01-2011, 15:33
J-Mech's Avatar
FRC #1361
Yes we have the IP set up for the cRIO and it is connected to the developer computer with the Ethernet cable. I connected the system to the classmate and it was a communications error(Fast Blink). I have verified that all of the IP addresses are set to what the manual gave for configuring the cRIO.
Unread 13-01-2011, 15:43
gr8dragon's Avatar
gr8dragon gr8dragon is offline
AKA: Parth Patel
gr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of lightgr8dragon is a glorious beacon of light
Im sorry if this is the wrong place to post this, but I am having great difficulty getting values from the vex ultrasonic sensor(using windriver). I seem to get either zeros or INF. Could it be the way i have plugged it in?
Unread 13-01-2011, 15:45
Team1811 Newark Team1811 Newark is offline
FRC #1811
Team1811 Newark is an unknown quantity at this point
Exclamation Re: IF NEEDING HELP POST HERE!
Thank you for your help. My Team is having an issue with just installing Labview. The file is corrupted and i was wondering if you had any suggestions regarding on how to uncorrupt it so we can start on programming already. We behind.
Unread 14-01-2011, 06:52
cjackson's Avatar
cjackson cjackson is offline
AKA: Cory Jackson
FRC #3502 (OctoπRates)
cjackson is on a distinguished road
Send a message via MSN to cjackson Send a message via Yahoo to cjackson
The DVD sent with the Kit Of Parts is corrupted?
Unread 14-01-2011, 09:23
DavidGitz's Avatar
If I understand what you're doing correctly, that won't work. The cRIO port 1 is the only port that can be used for communication, port 2 is for sensors/other devices. So from what I understand you have setup, you have the development computer connected to the cRIO port 1 (using an ethernet cable, which is wrong, should be a crossover). You also have the classmate connected wirelessly to the Bridge, and the Bridge ethernet cable is connected somewhere it shouldn't be.
The first configuration I would try is connect your development computer with a crossover cable to the cRIO port 1, and using the IP settings I gave earlier. If you can ping it, that means that the cRIO is imaged, I believe. I would stick with the LabView image if you follow my troubleshooting advice, since I don't have working knowledge of WindRiver. Then you should connect to the cRIO using LabView with a default project and build/run as startup to get working code on the cRIO.
After all these steps are completed successfully, I would start with checking out the wireless configuration/communication with the Classmate.
If you are unsure of anything I've said here, refer to these documents:
http://www.usfirst.org/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info/2011_Assets/Kit_of_Parts/How_to_Build_and_Load_Programming_in_LabVIEW,_C,_a nd_Java.pdf
http://www.usfirst.org/uploadedFiles...cRIO_Rev_A.pdf
I really wish they would have made the control system instructions in one document this year, so teams knew how to progress through the documents instead of a collection of separate documents. If they would have been consolidated (like last year) I believe that your team would probably not be having this problem.
Unread 14-01-2011, 09:28
DavidGitz's Avatar
Are you using the DVD's that came in the KOP? What kind of computer/OS are you putting it on? Can you post a screen shot?
Unread 14-01-2011, 10:15
DFZXA DFZXA is offline
FRC #3055 (Furious George)
DFZXA is infamous around these parts
Hi,
Our team is having trouble wiring the ADXL345 accelerometer to the bot. We have tried looking up diagrams of it, but there doesn't seem to be many and then there are just some manuals that are very confusing to us. Help is appreciated. Oh and we know that this isn't required to be on the bot, but it'd be nice to incorporate into the driving system so it doesn't feel awkward to push forward to make the bot go towards myself.
Unread 14-01-2011, 10:37
davidswan1962 davidswan1962 is offline
AKA: David Swanson
FRC #2540 (SPARC)
davidswan1962 is an unknown quantity at this point
I am having a hard time loading Labview on my Laptop. I am running Windows 7 and keep getting the errors I have attached. Also, when I re-imaged the Classmate, it wiped out Labview on my Classmate. I am going to a veteran team this weekend to try and get help, but was wondering if anyone else is having similar problems. I was going to try and use the Restoration Key for the Classmate from 2010, but it didn't work either. Any help would be appreciated!
Thanks,
David, Team 2540
Unread 14-01-2011, 11:03
Well first you can just install labview on to a separate laptop and then store it on the cRIO by using the build and run as start up thing. As for the classmate you don't really NEED to have labview on it as I kind of specified above. You may want to try reinstalling labview if you are running into errors otherwise can you specify the errors you are getting?
Unread 14-01-2011, 12:15
That looks like things are being installed out of order.
Did you:
  1. Install the LabVIEW DVD
  2. Install the LabVIEW Update
  3. Install the LabVIEW Utilities
  4. Install the Driver Station Update (if wanted)
Which one of these steps caused the errors you saw?
