Go to Post just a gentle reminder not to limit yourself to just one viewpoint - every problem can and should be examined from different angles - dlavery [more]
Unread 14-01-2011, 11:36
Drkinnes Drkinnes is offline
FRC #2549 (Millerbots)
Team Role: Scout
Drkinnes is an unknown quantity at this point
Ubertube question
Our team is wondering what happens when the Autonomous period ends and you still have an ubertube. We understand it is of no value but we are wondering where it goes. Is it kept on the gound or removed from play?
2549 Rules/Safety Committee
Unread 14-01-2011, 11:39
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Ubertube question
it is not removed from play, it remains on the field, and you're allowed to carry and possess it and move it around the field but scoring it is not allowed.
Unread 14-01-2011, 11:41
Team Role: Scout
Okay thanks
Unread 14-01-2011, 12:35
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
I also believe that if an ubertube is on the peg but not scored the ref will remove it from the bots grip and put it on the ground like they did in 07.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 14-01-2011, 12:43
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
The refs will enter the field, and approach a live robot DURING a match?
Unread 14-01-2011, 12:50
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
In '07, the refs did enter the field and removed (sometimes forcefully!) the keepers that weren't in scoring position. To do this safely, there was a delay between the autonomous and teleop portions of the game.
It took at most 15 seconds to remove the dead keepers, even when they had to cut / deflate them to get them away from the more secure grabbers. It barely affected the time of the matches.
My guess is that you will see similar steps.
"It's NOT Just A Robot Thing!"
Unread 14-01-2011, 12:53
AKA: Matt B
FRC #1771 (1771)
Huh, seems a bit drastic. What was the reasoning behind it? Why couldn't the drivers just drop the tubes after autonomous?
Unread 14-01-2011, 13:19
jblay's Avatar
AKA: Joe Blay
If the tube was on the peg but still in the robots control at the end of auton. Once teleop would start if the bot just released the tube it would score. To prevent that from happening they removed the tube from the robots grasp
Unread 14-01-2011, 13:22
AKA: Matt B
FRC #1771 (1771)
Ah, okay, that makes more sense. Thanks.
Unread 14-01-2011, 14:30
Jimmy K's Avatar
Jimmy K Jimmy K is offline
FRC #1002 (Circuit Runners)
Jimmy K is an unknown quantity at this point
This was being discussed in a previous thread (after the first few posts). http://www.chiefdelphi.com/forums/sh...ad.php?t=88375
Relevant quote below:
Originally Posted by GaryVoshol View Post
There is no prohibition against carrying ubertubes during teleop; you just can't score them then.
In 2007 there was a specific provision in the rules to remove keepers. I didn't see anything like that in this year's rules. In fact, I suspect that there will not be a pause between auton and teleop.
Unread 14-01-2011, 14:34
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
The refs will not remove the Ubertubes from play after Auto, teleop will continue as normal, and scored Ubertubes in Teleop will follow scoring rules according to <G16>.
However, something that isn't clear, is that <G16> states that a penalty will be given for scoring an Ubertube during teleop, but it doesn't say anything about it's respective doubling power being negated. Interesting.
Jacob
Unread 14-01-2011, 18:07
gbrettmiller's Avatar
gbrettmiller gbrettmiller is offline
AKA: Brett
FRC #2893 (The Robohobos)
gbrettmiller is on a distinguished road
Send a message via Yahoo to gbrettmiller
<G16> specifically disallows hanging of ubertubes during teleop. I interpret this to mean that they will not be scored, nor would they provide a bonus, even if you do choose to hang them anyway (and recieve the penalty).
Brett Miller
Mentor - FIRST 2893
gbrettmiller@gmail.com
240.428.8476
