Go to Post It's not all about the offensive "powerhouses", strategy is key. - smurfgirl [more]
Unread 13-01-2011, 23:00
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
Cypress I/O module update
Hello,
reading the pdf "How to Configure Your I/O Module" available at the kit of parts section of the FIRST website, they tell us to
5) In the top left of the tool bar, you’ll see a blue folder icon. Click the folder, browse to where you saved FRC_IO.v1.hex, and select the FRC_IO.v2.hex file.
but I could not find such files to download anywhere.
does anybody knows where to get them?
thanks!
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 13-01-2011, 23:10
Re: Cypress I/O module update
It was installed with the driver station update in the <public documents>/frc folder.
Unread 14-01-2011, 03:05
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Also, for anyone interested in modifying the firmware for the I/O module, remember that the source code is available at FIRST Forge. It's been quite a while since Bill's blog stated that it was open sourced.
-Joe
Unread 14-01-2011, 12:25
Daniel_H's Avatar
I just had an even more elementary problem.
The PSoC programer doesn't recognize the IO board.
Just below the Port Selection, where it should appear, it is blank and I can't get it to appear there.
I believe the driver is not installing correctly.. Is there a driver file anywhere so I can install manually?
[<o>] gogogo [<o>]
Unread 14-01-2011, 13:27
The driver is installed with the Driver Station Update.
