Go to Post And THAT is why they have safety manuals. - Eria4044 [more]
Unread 14-01-2011, 09:31
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
6WD: Which wheels to power?
We are very tempted to use the 6WD base that came in the kit of parts (simplicity, cost, agility, it's here now, etc.). The KoP frame, however, only powers the center wheel. I understand that a bot built this way can work (since the center wheel is hopefully always touching the carpet), but we're wondering about powering all the wheels.
Is working the details of chaining all six wheels worth the effort? Will powering only the center wheels put us at a disadvantage (pushing, for example)?
"It's NOT Just A Robot Thing!"
Unread 14-01-2011, 09:33
Racer26 Racer26 is offline
Re: 6WD: Which wheels to power?
Most teams using a 6WD base will link the wheels together with chains, gears, belts, or some other linking system I can't think of off the top of my head. Yes. I would highly recommend doing this.
Unread 14-01-2011, 10:35
Yes you will want to run chains to all six wheels. Unpowered wheels are dead weight.
Unread 14-01-2011, 10:38
Ideally, you want every wheel that is touching the ground to be contributing to your motive force. Since your traction is intimately related to the friction on your driven wheels, and since friction depends on the weight applied through those wheels, every non-driven wheel with any weight on it robs you of traction.
Unread 14-01-2011, 10:39
dodar's Avatar
dodar dodar is online now
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
The 2 most common ways I know how to power them is West Coast Style: you direct drive the middle wheel then belt/chain drive the other 2. The other way is to put the motor&gearbox between the middle and back wheel and then chain/belt to the back wheel and to the middle wheel and then the middle wheel sends chain/belt to the front wheel.(this way is more for redundancy, because you can lose your back wheels and still have 4 wheels that are driven and you can lose 4 wheels and still be driven by the back 2)(when i say lose i mean that they are no longer spinning, not that they have fallen off the robot lol)
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 14-01-2011, 10:40
dodar's Avatar
Unless you do a drop center to help with manueverability.
Unread 14-01-2011, 10:42
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
FWIW, it's not terribly difficult to chain all 6 wheels together, unless you're trying to do it with a single length of chain! 6 sprockets (1 motor, 3 middle wheel, 1 for each of the outer wheels) and some carefully cut spacers to make sure everything lines up properly, and your set!
Unread 14-01-2011, 11:37
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Stogi's pretty much right on the money here.
Every 6WD we've ever build has had each wheel powered, usually using two chains on each side. The front and center wheels are chained together and the center and rear are chained together - we use this method to add a certain amount of redundancy to our drive so that we know we can throw one chain on each side and still have some degree of effective maneuverability.
-Dustin Benedict
Unread 14-01-2011, 11:47
Chris is me's Avatar
AKA: Pinecone
Always always power every wheel.
Unread 14-01-2011, 12:02
Best Available Data
FRC #1778 (Chill Out!)
Yup. In a perfect world, your weight (or normal force) is perfectly divided between each contact point with the floor. So a 6 wheeled robot has 25 pounds of downforce one each wheel. You only convert that normal force into tractive pushing force if that wheel is powered -- otherwise you might as well just stick a caster there.
(Imagine you have a really heavy piano. If you put it on unpowered wheels, it is easy to move. )
Ie, a 6 wheeled robot (in a perfect world) with 4 unpowered wheels gets 1/3 the pushing of a robot with 6 powered wheels. If you do the dropped center wheel, then its likely 1/2, since typically only 4 wheels are on the ground at any given time.
Unread 14-01-2011, 12:31
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
All of them!
Unread 14-01-2011, 12:34
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Originally Posted by squirrel View Post
All of them!
QFT
Like Aquidneck Island Robotics on Facebook!
Unread 14-01-2011, 13:35
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
Remember that around the towers is a 1/2 plywood extending out under the carpet which could bring the center wheels off the ground if the front or rear ones hit it which would in turn loose traction.
Unread 14-01-2011, 15:04
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: 6WD: Which wheels to power?
When using 6 wheel drive, we chain to each wheel for redundancy. You can lose 2 of the 3 chains on a side, and still drive. Worth the extra effort IMO.
In addition, try to center the CG over the center wheel.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 14-01-2011, 15:30
MrForbes's Avatar
AKA: Jim
That's on the "team" field, not the official field, right? The official fields will have 3/16" aluminum plate under the carpet?
But yeah, ground clearance is a good thing!
