#31
Re: pic: Legal Frame ????????????????
One judge out of how many, about 20? I'd say it's very unlikely that more than 10% of the judges at any regional know the rules well enough to perform robot inspection. It's not their job. It's the robot inspectors' job.
#33
You're right, it's not the judges' job to know the robot rules well enough to inspect. But I wouldn't be terribly surprised to find that quite a few inspectors (or former inspectors, or refs, or mentors) are judges across the country. If we're counting "general idea, but can't cite the exact rule or knowledge a year or two old", then you might get up to about 25%. |
#34
Stop whining about something that can be fixed by working harder. Teams that have the resources to do lots of prototyping, design their entire robots in CAD, send the parts to machine shop sponsors, and assemble completed robots are the way they are because of a lot of hard work. These resources and relationships did not just fall in their laps. These teams provide their students a very engaging and rewarding opportunity to work with engineers and companies, to participate in an advanced engineering design process, thoroughly ideate and test prototype ideas, understand topics like manufacturability and limitations of various fabrication technologies, see how using CAD software significantly improves the final robot, and much, much more. Instead of whining about these teams, recruit engineering mentors. Recruit machine shop sponsors. Fundraiser throughout the year to afford lots of prototyping. Learn and become fluent in CAD software. With enough hard work, any team can become a top tier team. How do I know this is possible? When I first joined 228, we had about eight students and an annual budget of about $12k. Last year, our budget was probably among the top quarter percentile of FRC teams, we had identical practice and competition robots with parts made at our school, at two sponsor machine shops in Connecticut, and at one sponsor machine shop in California. We attended three official events and took home a Regional banner and Regional Engineering Inspiration award. We bucked the traditional advice against never designing a swerve for the first time during the build season, and did just that (and even made it able to drive over the bump), and other than a bearing defect issue (out of our control) got it working within the six weeks build. And we worked our collective buts off for the entire year, both inside and out of the six week build, to fundraise and get the resources in place to make all that possible. Our goal has never been to whine about the top tier teams, but to become one. Last edited by artdutra04 : 16-01-2011 at 23:06. |
#36
Also <R07-A>. Quote:
#38
Jim |
#39
The same way teams get rewarded after posting how they design their robot, send the plans to their sponsor, and recieve a kit back with all the parts cut, brackets bent and metal skins laser cut. A simple bolt together and they are hard to compete with. I say more power to them!! Last year we had 2 engineering students on the team ( still do) and we won the Excellence in Engineering Award at both districts we went to. Again it is because we have crazy imaginations that we encourge in the garage. We make our parts ourselves and we don't have ANY fancy machines and our budget is right around $1,200 for the year. ANYTHING is possible. ![]() |
#40
But this isn't true - there are allotments for bumpers going over various sized gaps in the perimeter.
#41
OK Ladies and gentlemen,
Time to quote the rules from Section 01 Introduction... FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the HOSTBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the FRAME PERIMETER, wrap a piece of string around the HOSTBOT at the level of the BUMPER ZONE - the string describes this polygon. Note: to permit a simplified definition of the FRAME PERIMETER and encourage a tight, robust connection between the BUMPERS and the FRAME PERIMETER, minor protrusions such as bolt heads, fastener ends, rivets, etc are excluded from the determination of the FRAME PERIMETER. This kind of says it all. Language similar to this was the rule last year as well. Hold a string around the frame and that describes the FRAME PERIMETER. The FRAME PERIMETER must be protected by bumpers and this year the rule under Section 04-The Robot R07-K allows some leeway that was not present last year, i.e.some gaps and some unsupported bumpers. The "T" robot last year and "hourglass" robot shown above fall under the same rule. A string wrapped around the robot at the height of the bumper zone would bridge the opening and therefore require bumpers attached to the robot everywhere the string exists. I failed a "T" design last year for the violation. I explained the rule and assisted the team in becoming compliant. As they were under size and underweight and had time to complete the needed mods, they played. In light of other game rules, (cough herding cough) it is easy to see why the FRAME PERIMETER is so defined. |
#42
It doesn't say the string has to be taught.....You could pull the string around the robot much like a seamstress would use a measuring tape to measure in their job. I took the string as more like a level line.
It is the exterior vertices part that means you can't have inside corners. Not to argue this anymore, but this is just a badly written rule. It would be much better to just say "inside corners are not allowed" Quote:
#43
Kevin,
Not to be hard on this but it doesn't say "wrap the string around your frame and push it in where ever the frame goes in". It simply says "wrap the string around... ". The above rule is specific to 2011 only and does not allow for interior corners. If the GDC changes the interpretation, I will inspect for that new definition. |
#45
Definition of wrap
wrap verb a : to cover especially by winding or folding b : to envelop and secure for transportation or storage : bundle c : enfold, embrace d : to coil, fold, draw, or twine (as string or cloth) around something Al, I am just having fun now, but I disagree per the above definition. When "wrapping" an oddly shaped present you would cover each segment as I have stated for placing the string around the robot. Cheers. Quote:
