Go to Post to all of the people who are on robotics, I thank you for giving me the chance and happiness that i had never had before. robotics has been the happiest thing i have ever done in my life - gondorf [more]
Unread 17-01-2011, 16:35
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: RS775 Gearboxes
Originally Posted by rahilm View Post
Based on our prototyping, watching some old 2007 videos, and current consensus on design, we've found that speed close to optimal. Of course, it's only week 2, and there's a lot more testing to do, so our plans may change quickly.
Sanity check: Strap a five pound weight on the end of a 2x4 and swing that from a pivot point about five feet from the end 180 degrees in a second.
Then try to precisely place a tube on a rack with that rotation rate.
I haven't done it, so maybe I'm talking out of my butt here... but that seems pretty darn fast!
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 17-01-2011, 16:51
pfreivald's Avatar
AKA: Patrick Freivald
Re: RS775 Gearboxes
What's wrong with 180 degrees in one second in this game (specifically)? You have half (or all) of the field to drive before you are in position to score, after all!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 17-01-2011, 16:52
rahilm's Avatar
rahilm rahilm is online now
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: RS775 Gearboxes
I guess I haven't been clear enough. We probably will be going with something slower for human control (as I said, week 2 just started, lots of testing to do still), I don't know of many people who would be able to control something that fast.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 17-01-2011, 16:57
Re: RS775 Gearboxes
It's far too fast to be easy to control, in my opinion. Most arms have about 90-100 degrees of travel. I"m thinking 45 degrees per second is much more reasonable.
Unread 17-01-2011, 17:01
rahilm's Avatar
AKA: Rahil Mehta
Re: RS775 Gearboxes
With some degree of automation (PID, specifically) and the proper control systems, you could go with a much faster speed without losing much control.
pfreivald's Avatar
Re: RS775 Gearboxes
Why, in the age of quadrature encoders and with targets at a set height, would you be subjecting your lifting arm to human control (beyond 'this is the height I want)?
Team 1551
I write books, too!
Unread 17-01-2011, 17:07
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Re: RS775 Gearboxes
Why subject your robot to a potential sensor failure when you can train a monkey (or a student, if monkeys are lacking) to put the tube at the right height every time?
Unread 17-01-2011, 17:10
Best Available Data
Re: RS775 Gearboxes
Because I trust software about as far as I can throw it, and since it has almost no mass, I can't throw it very far.
I know there are a lot of great programmers in FIRST. I also know that teams are always pushed right up to a deadline, and the software teams get very little time to test. I also know a slow arm is a lot easier to stop, and if your arm is going 180 degrees/second and you miss a limit switch for some reason, something is going to break. There are a lot of great teams in 2007 that didn't actuate at anything close to 180 degrees/second. There probably are some that did too, but I'm a lot more comfortable with a slow arm that I can fall back on a human to control, than needing a relatively complex piece of software to control.
Why would you use an encoder? It is simpler to use a potentiometer since your are limited to probably less than one revolution, no?
Unread 17-01-2011, 17:17
pfreivald's Avatar
Re: RS775 Gearboxes
A. Trimpots drift. Encoders don't.
B. The same idea could be replaced with "why do this in the age of the limit switch?" and the objection is the same (though with slightly different hardware and software, without quite so much elegance).
C. With 20 minutes of LabView training, I was able to bring an arm up to whatever height I wanted to by pushing the appropriate button.
D. If you haven't made things autonomous, then you can't score in autonomous...
Team 1551
I write books, too!
Unread 17-01-2011, 17:43
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
Re: RS775 Gearboxes
Banebot just emailed me back:
Hello,
The new CIM-U-LATOR gearbox and P60 mount for the RS775s will be available for order Wednesday.
Thank you,
BaneBots Sales
Jason Law
Unread 17-01-2011, 20:29
Re: RS775 Gearboxes
On the BaneBots page, it says they'll be offering a 64:1 and a 256:1 for the 775. Really? Nothing in between those ratios?
Unread 18-01-2011, 03:51
Best Available Data
Re: RS775 Gearboxes
Can you explain (in non-EE terms, preferably) how big of a problem this is in FRC style applications? In my six years of robot building we used potentiometers many times in the feedback loop for rotation, and many more times in our Operator Interface. We never had a problem, and none of my EE mentors ever mentioned it as a potential issue in our many hours of gremlin chasing. Did we dodge a bullet, or is this a case of "it only really matters when you're building spacecraft"? Thanks!
Unread 18-01-2011, 09:30
pfreivald's Avatar
Re: RS775 Gearboxes
The one year we used a trimpot, we found drift values of 5-10%. At one point it drifted sufficiently so that it was still driving while stalled.
We were the "oooh, neat, fire!" robot that year.
Team 1551
I write books, too!
Unread 18-01-2011, 09:36
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: RS775 Gearboxes
I would imagine that they may be the only packages for the RS775 that they offer off the shelf, but in years past swapping motors between BB transmissions was just a matter of ensuring you have the correct Mounting Block for the Motor and series of Transmission - so you should be able to buy a P60 with the desired ratio and swap the mount, right?
-Dustin Benedict
Unread 18-01-2011, 10:49
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: RS775 Gearboxes
Actually, on the planetary page for the P-60 for the RS-775, it says they have multiples of 4.
4:1, 16:1, 64:1, and 256:1.
