Go to Post But he who has deeper insight realizes that concepts and ideas canot be contained in even the largest jar, bucket or box. You cannot touch or see these things, but you can be enhanced with knowledge and experience of them. - sanddrag [more]
Unread 19-01-2011, 09:42
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: pic: 816's 2011 Frame (Teaser?)
Originally Posted by sdcantrell56 View Post
Yeah man we decided just to use 2 of the 550's to power our elevator since they are so equal in power and the transmissions were available
I ran some numbers with both the 550's and the 775's and while the 550 was capable of doing what we needed it to do, we felt that the added robustness of the 775 was something that we wanted.
Originally Posted by MattC9 View Post
Sweet!!! what made yall decide on 6WD?
There was really no reason that we could come up with to not build a 6WD. The field is flat, relatively unobstructed, and the game called for mobility, speed and pushing power (Or at least the ability to hold your ground), so we felt that 6WD was the best option to fit all of those.
Originally Posted by Brandon Holley View Post
What configuration (ie: gear ratios) of the Supershifter are you gonna be running? aka: what speeds are you shooting for?
-Brando
We're running the stock gear ratios on the Super Shifter. With a 6" wheel, we're looking at a low Gear of somewhere around 5fps and a high gear somewhere around 13fps after adjusting for efficiency and all that fun stuff.
-Dustin Benedict
