Go to Post in FIRST it's not just about where you finish in the standings but the intangible of inspiration where there is no true or immediate forum of measurement. - Koko Ed [more]
Unread 18-01-2011, 20:01
Sh1ine Sh1ine is offline
FRC #2791
pic: 2791 Concept Arm Frame
Unread 18-01-2011, 20:04
Re: pic: 2791 Concept Arm Frame
Probably should have sent this as an email, whoops.
Right now there's no room on the arm pivot for a sprocket or anything behind the pivot point. I'm not sure how to fix this but it looks like as long as the long 2x1 pieces are mounted on the back like that it'll be a problem.
Unread 19-01-2011, 00:22
MrForbes MrForbes is offline
see if you can get the arm to weigh 10 pounds or less...5 would be about right
then yeah, it's overkill....
Unread 19-01-2011, 01:09
Should be about right with 1.5" PVC and a roller claw.
Unread 19-01-2011, 09:54
They make 1.5" ABS sewer pipe too, it's lighter and tougher than PVC, and looks so cool since it's black. We're currently planning our arm to be made of 1.5" ABS at the manipulator end, and 2" ABS at the arm pivot end...it'll do an "extendo" maneuver at the beginning of the match to become a longer arm. If it all works, that is. The prototype is assembled, but not yet powered or mounted to a robot.
Unread 19-01-2011, 09:59
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
That's gonna make one heck of an obstacle when it's lying on its side in the middle of the field.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 19-01-2011, 10:10
Not if it self rights?
Unread 19-01-2011, 12:44
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Be careful of rule <R45>, It appears that you have three CIM motors on each of those drive gearboxes.
<R45> Motors specifically permitted on 2011 FRC ROBOTS include:
C. one or two additional 2½” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the KOP. This means that up to four, and no more, 2½” CIM motors can be used on the ROBOT,
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 19-01-2011, 12:54
We have 3 CIMs in the model, but we did that just because there wasn't a BB + CIMple Box model available while designing.
Unread 19-01-2011, 13:19
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Originally Posted by Sh1ine View Post
Please forgive the poor Photoshop Job. I am looking for a bit of advice. Although we have not nailed our arm manipulator design yet we want to be able to get the fixed upright welded when the rest of the frame is in the shop. Currently I have it drawn with 1/16" wall tube. The two vertical pieces are 2x1 the rest are 1x1. Do you think that this system will be strong enough to support a arm that can reach to the top peg and weights around 30 or less lbs? Is it overkill? Thanks.
On 330, we put our mast back a few inches to allow room for a big sprocket at the top. http://www.chiefdelphi.com/media/photos/27675. We use 2x1 1/8" for the mast, which is probably overkill.
Unread 19-01-2011, 17:10
AKA: Scott
Gotcha, Just wanted to make sure.
