pic: Teaser manipulator
Re: pic: Teaser manipulator
Nice!!! but the real question did it work well? Because We had a similar idea to it.
For concrete jersey barriers?
I would be carful with that getting ripped off your robot during collection.
When building a ground-picker-upper ask yourself would this break if a robot hit it square on going 10fps? |
at this point the grabber is not completed. it needs more bands and they will be tighter. nevertheless, it grabs, and almost turns the tubes. fine tuning will be done. Effective? Yes i think so.
Is that some type of urethane tubing you are using? If so, how did you weld/join yours together, they look nice and neat.
The orange cord is called polycord you can order it from Mcmaster-carr, it is joined by heating the material up, joining it, then letting it mold together and cool. Works really good for a variety of FRC and other applications.
This looks really HEAVY. Whats it weigh in at?
I agree with sean it looks really heavy ,but if you are able to lighten it i think it will be very useful for manipulating the tube.
#10
I agree also, It seems that straight roller supports mounted nearer to the axles of the inboard pulleys would make it much lighter.
#11
If you mounted the larger pulleys concentrically with the pivot for the corresponding 'finger' the belts would maintain tension as the grabber opens and closes.
#12
It weighs in less than 5 lbs and the reason for the offset of the drive pulleys is so we can tension it. The arms wont move during the game.
#13
The way we mold it, not the team whose photo this is, together is we took a piece of aluminum block. drilled through the center of it with a bit as big as the diameter of the polycord. then we sliced the block in half at the point where it was drilled through. then we melt the polycord and put it in between the 2 pieces you have left and you get a nice and strong connection. |
#14
This entire thread is very helpful when it comes to polycord. |
#15
I think the concept is good but it could be cleaned up a bit...
is this just a prototype? HINT: the tube surface is very different than in 07 and I believe that wheels work better than belts. Also in a collision belts may come loose easier than wheels... |
