Originally Posted by poohbear
-these four wheels are directly driven by CIMs so we can zip across the field at 154 fps according to JVN Design Calculator (great tool by the way guys).
Wow...just...wow. I thought fast would be good but, at those speeds you should be able to use the Lorentz Contraction to get away with a larger manipulator into the 84" cylinder (the refs will never be able to tell!). This is sheer brilliance! Have you considered the possibility of using the
Picard Maneuver in match play?
