Re: pic: burnt up TETRIX motor
Originally Posted by Bill_B
The part that failed is the cylinder-ish one in the back, right? The blue blob is a shunt capacitor I think. It tries to reduce the brush noise on the power input line. If that shorts, you will blow a fuse every time. The smoke some others mention may also be from the part that failed here; just on the verge of failing.
yes the resistor is very burnt up and cracked right in half
the shunt capacitor looks fine
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
