Go to Post Use the mentor to lay down the law. They're not there to be your friends they're there to keep the kids focused on the job at hand. - Koko Ed [more]
Unread 23-01-2011, 08:07
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Re: pic: burnt up TETRIX motor
Has anyone experimented with the use of a 10A fuse in place of the 20A "default" fuse? Haven't seen it discussed elsewhere.
As long as the fuse survives the inrush current, it appears that it should hold during a "normal" climb using two motors near the max power operating point, yet still open reasonably quickly once a locked rotor condition occurs. Perhaps this would have prevented the OP's issue altogether - or maybe not.
Our plan was to do this during build season, then revert to the 20A fuse for competition (and even then, replace that fuse every few matches). The worst-case scenario *seems* to be that there might be a lot of nuisance fuse openings, but it would be far less expensive to replace fuses than motors.
Last edited by ayeckley : 23-01-2011 at 08:09. Reason: Tied the logic back to the OP.
