Re: pic: 2011 Team 498 Robot
That sounds great, then, and clears up the only confusion that I saw. Thanks!
CG looks a lot higher than I would like.
its nice to be able to compare... Right now our teams seem to be in similar stages. Solid design. Is everything hand welded and cut?
Yes. All cut and welded in a fellow mentors garage. The tower is actually made from a thin grade stainless steel. Ended up being lighter and stronger than a thicker grade aluminum.
