Go to Post So the bar is set insanely high. Probably unachievably high for some of us. But what a shame it would be to lower it. - pfreivald [more]
Unread 23-01-2011, 21:25
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
Re: necessary torque for an arm
I'd suggest some possible safety issues in addition to what has already been said. That heavy of an arm going at those speed could do serious damage to other robots. I'm all for an aggressive game, but lets not crack each others lexan.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 23-01-2011, 21:29
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
This is assuming a 10 lb manipulator approximately five feet away from the closest pivot point on our four-bar linkage.
Unread 23-01-2011, 21:36
Molten's Avatar
AKA: Jason
10 lbs isn't bad considering that. Is that including the weight of the arm itself? or is that just the actual manipulator on the end? If your considering the weight of just the manipulator, your numbers are going to be a bit low. If your considering the weight of the arm too and are placing it at the end, they will be a bit high. You should be placing the weight of the arm at the midpoint of the arm and it should give a pretty good approximation. There will be a bit of error because of various things, but you should be pretty close.
PS: I'm intrigued by the thought of a 5 foot long manipulator.
EDIT: Also, don't forget rotational inertia. Its easy to focus on gravity being your resistance that is fighting you, but it isn't the only one. You also need to consider rotational inertia. You should be able to do some research on it, but if you continue to have problems after that...give me a PM and I'll help you through the math.
Unread 23-01-2011, 21:58
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
That pesky Tnet=Ia equation?
Not too concerned about that, especially since it looks like we'll be going with 126 ft-lbs of total torque.
Unread 24-01-2011, 08:06
Gdeaver Gdeaver is offline
FRC #1640
This year there are going to be some heavy arms with heavy manipulators hang way out there. As noted the forces on joints, motors and gear boxes are substantial. We are going to use a passive device to balance the arm so that the gear train only has to hold position not lift the entire load. Fiber glass pultrustions can reduce weight over AL.
