Go to Post *referring to Team Titanium's 2012 robot* If only it could play guitar hero at the same time. sigh. - rsisk [more]
Unread 24-01-2011, 09:23
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Re: pic: burnt up TETRIX motor, excellent post
Originally Posted by caffel View Post
Maybe we could use a small cricuit braker in series (they go down to 3 Amps, although hard to source in that rated size)
The response times for circuit breakers are typically much longer than for equivalent-value fuses. If you go this route (and if it's determined to be FRC2011-legal), make sure to check that the response time of the device is within whatever time you decide is acceptable. Based on what I'm reading, it sounds like it would need to trip within 1 sec @ 7A (assuming one per motor) to prevent the "smoking" issue.
