Go to Post I think overcoming obstacles together builds a stronger team. - MissInformation [more]
Unread 24-01-2011, 23:46
ttldomination's Avatar
Sunny
Re: pic: MMRambotics Chassis
Originally Posted by seannoseworthy View Post
The battery wont swing, the whole assembly you see there is welded. Plus the Velcro strap, it wont be going anywhere.
It doesn't matter if that frame is welded or Dean Kamen is on the robot holding it together. The entire thing is only supported from the top, and then the battery drops down. The torque about the two points of connection is going to be alot. The battery mount might not fail, but you will see some swing/rotating when you accelerate/decelerate.
- Sunny
1648: 2013-2014
5283: 2015
