Go to Post This is how students can be inspired! - Rich Wong [more]
Unread 25-01-2011, 10:28
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: How to get the mini bot down
The GDC already ruled that a small step ladder violated <T25> http://forums.usfirst.org/showthread.php?t=16331
Originally Posted by JB987 View Post
Granted, I don't see what competitive advantage a pole to retrieve a robot provides
It keeps your minibot from being destroyed by Dean's chainsaw, which is a big competitive advantage in future matches.
Unread 25-01-2011, 11:03
JesseK JesseK is online now
Technically, by that wording of <T25>, tools to discharge a pneumatic mechanism and/or pick up a robot are illegal as well; yet I haven't seen a single judge or referee ever say anything about them. Particularly, Curved T-handle hooks are used by a few teams to pick the robot up. Usually these items are in the best interest of safety, and the only 'competitive' advantage they provide are allowing the drivers to safely retrieve game pieces and/or lift the robot without straining their back, in order to stay healthy for future matches.
It will be interesting to see the implications of enforcing <T25> as worded.
Unread 25-01-2011, 11:34
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
The real alternative is to design your minibot to come down autonomously as it's last action so that it is at the bottom when you go to retrieve it...
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 25-01-2011, 12:01
JB987 JB987 is online now
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
But the challenge is how do you get it to come down at a reasonable speed if you are not using the NXT to reverse and lower the motor speed used to climb the tower because you are using the lightest, bare bones design for the climb and if you are geared such that you aren't going to backdrive with gravity's help? Assuming you have found that such ratios that allow backdrive increase likelihoold of stall conditions for the climb...
Unread 25-01-2011, 12:14
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
Our Victors have brake and coast modes. No reason you can't make a minibot have a "brake" mode too!
Unread 25-01-2011, 12:46
Electrical Engineer
Rookie Year: 1995
Indeed...
Mike Betts
Unread 25-01-2011, 15:27
GaryVoshol's Avatar
Cogito ergo arbitro
<R11>, blue box:
Note that the total weight of the ROBOT, MINIBOT, BUMPERS, and battery may approach 165 pounds. Please think carefully about lifting the weight safely. Teams are encouraged to use their forth TEAM member (typically in charge of the ROBOT cart) to carry the MINIBOT on to the FIELD separately. Teams are also encouraged to think about handles or lifting bars to aid in lifting and carrying the ROBOT.
Now it doesn't say, one way or another, whether those are removable lifting bars or handles. But as has been noted, separate carrying devices have been used in the past.
<G07> Items other than the ROBOTS and the GAME PIECES shall not be placed on the FIELD prior to or during the MATCH. Violation: PENALTY and YELLOW CARD
... says nothing about after the match.
I'm not sure how this works with <T25> - someone will have to ask.
(since 2004)
Unread 25-01-2011, 18:19
Bob Steele's Avatar
On the RIBMEATS bandwagon....
AKA: Bob Steele
I asked the question in Q and A today.
1. Is a pole legal to bring on the field to help retrieve the minibot.
2. If the pole is part of the robot and detached at the end of the match can it be used to retrieve the minibot?
3. If the pole is part of the drive console and is detached at the end of the match can it be used to retrieve the minibot.
I also mentioned that this is a safety issue and that this device would not give a competitive edge to any team.
It will be interesting to see what they say.
I personally don't know how they can no to either 2 or 3 and then it will be pretty silly to say no to 1...
We will see
B
Unread 26-01-2011, 00:00
AKA: Joe Barry
Thanks, Bob! I look forward to seeing a common sense reply from the GDC soon...
Unread 26-01-2011, 00:51
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Have the minibot have an ejection system with a parachute. Its safe and its cool to have the bot just float down by itself.
Now I am not an EE major or anything; but can't you use resistors to restrict the flow of electrons to the robot? So less electrons flow through, the slower it goes. Isn't that how it works?
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 26-01-2011, 01:19
AKA: Joe Barry
Resistors would indeed reduce the flow of electrons...trouble is I don't see resistors listed in R92 that details what can be a part of the minibot.
Unread 26-01-2011, 02:51
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
What about a diode that would connect the two poles of the motor together when it's moving backward and not do anything when it's forward?
Like.. put the anode on the end where the 12V is applied and the cathode on the end where the GND is. That would reverse the diode when power was applied, but when the power was shut off and the motor started generating power, it would go through the diode and act as a brake.
Now if we build our own diodes out of some sort of electromagnet, is it legal?
Unread 26-01-2011, 08:10
Even without a resistor, you can just shunt the + and - leads of the motors together to use the internal resistance of the motor itself as your brake.
Try spinning the shaft of a CIM with the leads disconnected from everything. Then connect the two leads together, and try again.
