Go to Post Is the bottom slot just to make the whole thing look like a smiley face, or is it functional? - Chris is me [more]
Unread 25-01-2011, 19:47
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Re: pic: FRC 2415 Robot design v1
Originally Posted by RMS11 View Post
we are using a continuous timing belt loop. It should go from bottom to top in about 1.5 seconds powered by 2 550's. The lift is three stages. Thanks for the compliments. Unfortunately, we will not be attending Palmetto this year.
My mistake. Proof not to believe everything you read on the internet, I guess.
Unread 25-01-2011, 20:07
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Do you have a mechanism to prevent gravity from dropping your lift down? Are you using some sort of anti-backdriving gearbox?
What is the clearance from the bottom of the center wheel to your Al tubing?
Very pretty. Looking forward to seeing this at Peachtree.
Unread 25-01-2011, 20:20
So this is what happens when Sean gets to help design for 2415
Looks sick. I'm disappointed that you said you won't be at Palmetto.
Unread 25-01-2011, 21:27
zbutner zbutner is offline
AKA: Zachary Butner
FRC #2415 (Wiredcats)
Team Role: Student
zbutner is an unknown quantity at this point
Sean just eats our food and catches up on the reading for his bookclub.
And the only tragedy with this robot is that our captain doesnt want to hook up LEDs to a jaguar like we did last year.
If you read this and think that throbbing LEDs would look cool on this robot, please post "yes" so our captain will be persuaded !!!!
Unread 25-01-2011, 21:32
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
yes!!!
Unread 25-01-2011, 21:38
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
actually, sean does just eat food...he sometimes comes up with good idea.
but on a serious note, the robot is very very much designed by students. the mentors on 2415 like to relax, eat food, and play soccer inside.
YESSSSSS i want throbbing LEDS
Unread 25-01-2011, 21:40
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Second the "yes!!!"
It looks great! My team is using a 2-stage elevator with a continuous chain loop for VEX Round-Up, and it works like magic! Hope it works for your team, too!
Is the structure attached to the front of the elevator a tube manipulator? If so, how exactly does it work? Thanks!
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 25-01-2011, 21:45
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
Yes!
How does your mini-bot deployment system work? Does the mini-bot just sit on top there or is it something a bit more complex?
Unread 25-01-2011, 22:41
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
bobosalad is an unknown quantity at this point
looks heavy. looks strong. looks awesome
Spartans, Prepare for GLORY!
Unread 25-01-2011, 22:52
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Can I cry now, that is just beautiful!
1058 PVC Pirates 2016 - xxxx
Unread 26-01-2011, 00:39
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is online now
AKA: Sean
FRC #2415 (Wired Cats)
Pretty much the only reason I joined 2415 was for the support of my bookclub. What can I say...after all these years of actually helping design and build it feels so nice to be able to sit back in a big comfy chair and put my feet up while reading a good manly book.
Mentor 2415
Unread 26-01-2011, 00:43
ttldomination's Avatar
Sunny
Sean, the CD community might be fooled, but I am not.
There are NO book clubs at tech. Hell, we play video games in English class, and you expect me to believe a book club. You sir, cannot put the metaphorical book over my eyes.
- Sunny
1648: 2013-2014
5283: 2015
Unread 26-01-2011, 11:07
santosh's Avatar
santosh santosh is offline
AKA: 2415
FRC #2415
santosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond reputesantosh has a reputation beyond repute
Send a message via AIM to santosh
In all honesty, Sean is a great mentor and has aided us this year greatly in conceptual designs and helping with fixing certain issues. That being said, the actual cad was done almost entirely by the students of 2415. It brings 1 lonely tear to my eye when I think about how this is my last year as a mentor for these kids. to see the progress they have made is amazing over these years.
I for one as a mentor do actually only come for comedic relief, the free food (broke college kid), and because I know I can serve as a spiritual guide/father figure to these students. And because they need someone there to make sure they don't chop their hands off. And to keep Sean and Andrew company on these cold winter nights.
-one lonely tear.
