Go to Post It isnt about winning and losing (although getting the trophies and medals are nice) - Winged Wonder [more]
Unread 26-01-2011, 23:38
Re: pic: So, Andy Mark was sold out!
Originally Posted by seannoseworthy View Post
The stock is held down with the dogs you can see, once the tooth profile is cut there is about 10-20 thou of material left and at that point i removed the sprocket from the stock material and began filing.
If you did the whole operation on a fixture plate, you could probably mill the bore, then drill and tap a hole in the fixture plate, then put a bolt with a fender washer in it, then cut through the entire outer profile. Just curious, what did you use in CAD for the tooth profile?
