Go to Post Look guys, I am telling you for the fourth time - you are NEVER going to earn your official "Geek" certificates if you keep spelling "pwned" with an "O" in it! - dlavery [more]
Unread 01-27-2011, 10:24 AM
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
pic: Team 842 Arm and Grabber Concept
Unread 01-27-2011, 10:26 AM
MrForbes MrForbes is offline
Re: pic: Team 842 Arm and Grabber Concept
Ahhh...so that's what it looks like. Neato! Might be easier to devise a way to mount the "mast" if you put it at the other end of the robot? (ie. turn the whole chassis 180 degrees from how it is now)
I'd suggest you add sheet aluminum to your materials arsenal....but you'll have to do some fancy political maneuvering to get past the "fiberglass only" mindset
Unread 01-27-2011, 11:44 AM
Bernoulli Bernoulli is offline
Bernoulli is an unknown quantity at this point
just remember with the mast you have you may need to have some anchors as well so that it does not move at all otherwise you may have some problems later on if the mast is not secure to the frame properly also how are you goin to move the joints? motors or pnumatics? or a combination of both? looks great though keep it up
Unread 01-27-2011, 12:45 PM
ewrado's Avatar
ewrado ewrado is offline
FRC #0842
ewrado will become famous soon enough
Yeah the cad is not right the mast will be on the other side not under the motors as for the mounting it will be strongly supporter on the base and triangulation with guide wire or angel maybe aluminum tube
Unread 01-27-2011, 12:53 PM
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
That reminds me of 1523's arm in 2007.
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
Unread 01-27-2011, 12:54 PM
ewrado's Avatar
FRC #0842
The joints they are going to move with a signal rotational motion coming from a transition some where closes to the frame this year we are not putting any pneumatics on the robot its to heavy
Unread 01-27-2011, 12:58 PM
ewrado's Avatar
FRC #0842
similar but it more of an up and down movement we will hopefully have a video soon
Unread 01-27-2011, 01:04 PM
TheOtherGuy's Avatar
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
Neat! I can't wait to see it in real life
The mast reminds me of our 2007 robot, which had a round mast in roughly the same location. We attached a block on the belly pan that fit inside the bottom of the tube and then cut a hole in a sheet of aluminum that was then attached to the frame across the top.
http://www.photos.project1726.org/al...0/IMG_1681.JPG
