Re: pic: What is this?
Were thinking of doing something extremely similar to this. As this is only are 2nd year would you mind answering a few questions.
What size/type 8020 did you use? How do you mount the sprockets to the end of the 8020? Thanks. |
Standard 1" x 1"; if you need the exact part number I can dig it up.
Interesting. Looks like things are coming along.
How 'bout a quick vacuum of the robot frame? ![]() -Nick |
Good idea! My only warning is that we used 80/20 in the past to build a forklift (2008) and unless everything is 100% lined up, you're going to start building up a lot of friction. Given that we had quite a bit more on the end of the forklift though which contributed to the problem, I'd still watch out for friction, it's a killer.
Another question. Do you have a chain on each side of the lift, and if so are both sides powered or does one side just free slide?
What motor are you planning to use. My team is planning to use either a fisher price or window for our motor, and we can't decide.
