Go to Post FIRST builds bridges, and absolutely should not build walls. - Jacob Bendicksen [more]
Unread 30-01-2011, 07:38
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: What is this?
Originally Posted by Mr_I View Post
YES! We discovered that #35 chain fits almost perfectly between adjacent pieces of 8020. Add to that the fact that the steel-to-aluminum friction is very low, and you've got a very good thing.
We mounted two verticle pieces of 8020 to the drive train frame, and ran the chain down the slot to a "elevator car" that rides on two pieces of 8020 about 12" long. (There's about 1/16" gap between the car and the rails, so there's little side-to-side drag. ) The car is attached to the chain at the top and bottom, and the chain loops out the bottom via sprockets back to the top. Add a Barbie to drive the sprocket, and we've got a low friction high strength elevator!
Your saving grace here is that the aluminum used for in 8020 is anodized. The anodized layer is very hard and wear resistant. Without this layer the aluminum would quickly gall and cause an immense amount of friction. I would definitely keep those slots greased or oiled in case the anodized layer starts to scrape off!
Unread 30-01-2011, 08:58
IceStorm IceStorm is online now
Mentor FRC 5046, FTC 8688
AKA: Chad
FRC #5046 (Jacked Up Jackets)
IceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of lightIceStorm is a glorious beacon of light
Send a message via AIM to IceStorm Send a message via Yahoo to IceStorm
Another question. Do you have a chain on each side of the lift, and if so are both sides powered or does one side just free slide?
Unread 30-01-2011, 12:37
LondonBoy29's Avatar
LondonBoy29 LondonBoy29 is offline
A Man 3000 Miles away from his team
FRC #1884
LondonBoy29 is on a distinguished road
What motor are you planning to use. My team is planning to use either a fisher price or window for our motor, and we can't decide.
