Go to Post However, mentoring isn't for you. It's for the others. - Alan Anderson [more]
Unread 30-01-2011, 14:22
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: pic: FRC488 Octocanum.
Could you elaborate a bit on that please.. How does making the wheelbase longer accommodate rapid changes in direction?
Rapid direction changes + Short wheel base + tall manipulators = Tipping
The longer the wheel base, the less likely you are to tip when accelerating hard or coming to a hard stop.
Unread 30-01-2011, 14:47
Joining the 900 Meme Team
FRC #0079
However, mecanum is not at all like full blown swerve. The bot tends to drift a little bit as the rollers spin which should help remove some of the problems typically associated with rapid direction changes and tall manipulators. That being said, I still would not change direction at full speed (or even drop those traction wheels) if I had any sort of large mass up top. But knowing what I know about 488 they will have thought that out already (this ain't their first rodeo with mecanums).
Cool system, glad to see someone went with it, hopefully the ability to strafe will be beneficial.
Unread 30-01-2011, 17:37
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
I'm very curious as too why you put the traction wheels on the inside as to opposed to the outside. As of now it appears that you are not really taking full advantage of switching wheel base sizes. Why not put the traction wheels in the longer wheel base configuration to make it that much more difficult to turn as opposed to the mecanum wheels which could be made to preform equally well on the shorter (inner) wheel base?
Otherwise, really cool.
Unread 30-01-2011, 23:15
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We prefer to call them über-mecanums.....
Unread 31-01-2011, 09:12
dmaldonado's Avatar
dmaldonado dmaldonado is offline
FRC #1708 (AMP'D Robotics)
dmaldonado is infamous around these partsdmaldonado is infamous around these parts
Well team 1708 did a very simalar design
http://www.chiefdelphi.com/media/photos/34890
Unread 31-01-2011, 09:55
Racer26 Racer26 is offline
I like the idea. If the execution can be made perfectly reliable, it should be a formidable drivetrain. The trick comes in ensuring theres no problems with throwing chains etc.
Unread 31-01-2011, 11:23
1708xMr.Roboto's Avatar
1708xMr.Roboto 1708xMr.Roboto is offline
Eddie
AKA: Eddie
FRC #1708 (AMPED Robotics)
1708xMr.Roboto will become famous soon enough
Send a message via AIM to 1708xMr.Roboto Send a message via MSN to 1708xMr.Roboto
Originally Posted by LLogan View Post
I have been waiting for somebody to create this.
Looks like you have the best of both worlds. Where are you going to place the piston? I'm having a hard time visualizing where you'll be mounting it.
What configurations are you going to have your wheels in? I.e. four traction only, four mecanum only, 4 traction + 4 mecanum, etc.
Team 1708 actually did something like this last year..
Check it,
Facebook 1 - Chief Delphi 19382193
Unread 31-01-2011, 12:25
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
We anticipate using the mecanum wheel set most of the time, so we wanted that to be our most stable configuration. The traction wheels are not really intended to prevent others from turning us in place, but to kindly remove defense from our path when the mecanum wheels can't get us around it.
--Madison--
...down at the Ozdust!
Unread 31-01-2011, 12:33
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
<snip> to kindly remove defense from our path when the mecanum wheels can't get us around it.
Well said. Never know when you'll need to gently escort someone across the field.
I really like this drive, I feel like it negates the majority of the disadvantages of a Mecanum Drive in a relatively simple and elegant method.
-Dustin Benedict
Unread 31-01-2011, 12:38
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
When you guys assembled those mecs, did you do anything special, like grease the washers at the end of each roller and/or replace the washers with nickel plated ones?
Unread 31-01-2011, 12:47
Madison's Avatar
FRC #0488 (Xbot)
We checked that each of the rollers is spinning freely, but did not do anything otherwise special to them. As we run the chassis in, we'll see how they behave and make adjustments as necessary.
--Madison--
Unread 31-01-2011, 13:35
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Hi Madison,
Looks good. The Robowranglers built an octocanum platform this fall. Do you mind my asking -- what are you geared at for the mecanum drive?
-John
Unread 31-01-2011, 13:39
Madison's Avatar
FRC #0488 (Xbot)
Originally Posted by JVN View Post
Hi Madison,
-John
It's geared at 8.9:1 right now.
--Madison--
Unread 31-01-2011, 14:13
JVN JVN is offline
@JohnVNeun
Interesting. That is much faster than I expected.
I look forward to seeing video of it in action so I can recalibrate my mental picture of performance.
-John
Unread 31-01-2011, 14:15
Madison's Avatar
FRC #0488 (Xbot)
-John
I think it's a bit faster than I expected, too. We're going to get a bit more weight onto it soon and test it again under more realistic conditions to get a sense of whether or not it's something we can handle.
We've got rookie drivers this year and haven't found an area large enough to let it run at full speed for more than about a second, so necessity may require that we slow it down.
--Madison--
