Go to Post First off, let me suggest that you read the rules! There is an amazing amount of really good information in them. - dlavery [more]
Unread 01-02-2011, 13:37
Madman503 Madman503 is offline
AKA: Jon Skowronek
FRC #0503 (Frog Froce)
Madman503 is an unknown quantity at this point
Re: pic: Team 3547 'Our Ocotcanum'
Originally Posted by Jeffy View Post
The wheel pod appears to be mounted on a fulcrum (as opposed to a linear slide), but the pneumatic cylinder does not. How does this function? Everytime I have used an acuator of sorts, the base of the actuator has needed a fulcrum.
Does it rely on the flex of that aluminium bar?
It’s a solution our lead design mentor came up with. It’s in that aluminum block the cylinder connects to. Sorry for being vague I’m not sure how much I’m allowed to give away.
And to rutzman, we chose that as a way to both make the length of the module shorter and naturally geared 2:1 and whatever we choose for our sprockets on the wheel. As far as side loads in the traction wheels are concerned we haven’t had a real problem they were made very sturdy and shouldn’t be a large issue. All the ratios, other than the obvious 2:1 from the wheels, are classified. Sorry.
FYI. im mentoring on 3547, i used to mentor for frog force (503)
