Go to Post Dave Lavery says it's pimp? I don't care if the Pope says it's pimp, it still doesn't pass inspection! - MissInformation [more]
  #31   Spotlight this post!
Unread 04-02-2011, 10:06
WarehouseCrew WarehouseCrew is offline
FRC #3299 (Warehouse Crew)
Team Role: Parent
WarehouseCrew is an unknown quantity at this point
Re: pic: burnt up TETRIX motor
Could anyone using the Tetrix fuse protected motor power cable answer a couple questions:
1. Does it prevent burning up the Tetrix motors (eg. live up to its promise)?
2. Does the fuse act like a circuit breaker (eg. when it cools down it works again) or do you need to replace the fuse/power cable once it has prevented a motor stall ($9 vs. $30 for motor)?
3. If it is a "fuse" that is destroyed while preventing damage to the motor; can just the fuse (hopefully less that $9) be replaced on this cable without violating the FIRST rules?
4. Is this the cable people are referring to regarding thermal protection?
Thanks.
