Re: pic: Compressor Size Comparison 4
We kept having an argument over using the 120 or the 40, so I brought in a 2pin 80mm fan as a happy medium but if we cant use it then we'll probably switch to the 120. Last edited by klmx30302 : 05-02-2011 at 07:38. |
No need to put a fan on the compressor for competition use it is designed to take the heat. It's native environment is under a vehicle hood which can reach an "ambient" temp of ~200 degrees and it's 9% duty cycle and max run time of 3 minutes was developed for long term longevity (many years) operating in that environment. Of much bigger concern is the fact that you removed the factory installed check valve. You need to remove your manifold and install it after the check valve. That will allow it to release some of it's head pressure internally to reduce the start up load. Running it w/o the check valve voids it's warranty.
Wow, huge size difference from the other one. How does this years compressor work compared to last years
