Go to Post The culture has shifted, people. You can act shocked and complain, and likely lose the attention of the students you want to reach through FRC and other activities, or you can shift with it, and make FRC relatable and relevant to a bunch of good kids with foul mouths. - mrnoble [more]
Unread 06-02-2011, 00:57
Mr V's Avatar
Mr V Mr V is offline
FIRST Senior Mentor Washington
FRC #5588 (Reign)
Mr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond reputeMr V has a reputation beyond repute
Re: pic: Compressor Size Comparison 4
No need to put a fan on the compressor for competition use it is designed to take the heat. It's native environment is under a vehicle hood which can reach an "ambient" temp of ~200 degrees and it's 9% duty cycle and max run time of 3 minutes was developed for long term longevity (many years) operating in that environment. Of much bigger concern is the fact that you removed the factory installed check valve. You need to remove your manifold and install it after the check valve. That will allow it to release some of it's head pressure internally to reduce the start up load. Running it w/o the check valve voids it's warranty.
Unread 18-02-2011, 22:00
jman22890's Avatar
jman22890 jman22890 is offline
AKA: Jordan Hostick
jman22890 is an unknown quantity at this point
Wow, huge size difference from the other one. How does this years compressor work compared to last years
