Go to Post In the end the important thing is that the rookie members who make up the majority of our team were inspired and will try much harder next year. :) - aeniug2 [more]
Unread 07-02-2011, 18:22
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Re: pic: burnt up TETRIX motor
We had the same problem, a burned out motor. I assume that it is a blown inductor. How many amps will blow out the inductor? And is there an acceptable fuse that will prevent this from happening, preferably one that fits in the battery's fuse clip?
Thanks,
David
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
