Go to Post Without compromise, engineering would be boring. - Mike Betts [more]
Unread 09-02-2011, 22:36
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Re: pic: Team 399 Electronics
Originally Posted by DRH2o View Post
Looks nice. Questions -- 8 40 amp circuits? We can only use 4 cims, what are the others for. You will want to pull the breakers from the other lower amp circuits you are not using -- all are full with no wires.
Dan,
The breaker is sized for the wire it feeds. 40 amp breakers can feed #12 or larger wire. Good call on removing breakers on unused circuits.
Dude,
Very nice job. A recommendation would be to tie down the power wiring going to the Jags close to the Jag so it doesn't get pulled out of the connector somehow. Can you see the LEDs on all your Jags?
Al
WB9UVJ
www.wildstang.org
________________________
