Go to Post If there's one thing I've learned, it's that the robot is never truly finished. - Joseph Smith [more]
Unread 10-02-2011, 02:10
Re: pic: In_CIM_erator
Originally Posted by Hawiian Cadder View Post
i am aware, but (4/9) times to 200 watts max power that the supplier has tested for still leaves less than 100 watts of power, unless it is the 14.4 V nominal opperation motor, in which case it will output around 70 watts. according to the people who made the motors, there is no way any of them that size will output more than 100 watts at 12 volts.
also, power is current * Voltage
according to the Bane Bots website peak efficency current is 5.7
5.7 * 12 is 68, which fits the 70 watt power output number, i think all the other info on the BaneBots website is correct, except the power calculation, think that was taken at 18 volts.
The mechanical output power can be calculated from torque times speed.
If you take the motor at half free speed, it is also at half stall torque, for the 775 this works out to over 250W of power.
