Go to Post A good defense can defend against a good defense. - Squeakypig [more]
Unread 10-02-2011, 02:40
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Re: pic: In_CIM_erator
the Series of Motors are only rated for 200 watts total, which leads me to believe that have quite a bad bias, (they are for drills after all) and i do not believe that those are the motors we have, the smaller rs775 more closely matches what we were supplied, if the Bane-bots 12v is one of those, but at 12v, then it will be a different size physically, the smaller series of motors here: http://www.mabuchi-motor.co.jp/cgi-b..._ID=rs_755vcwc
and 4/9 times 270 is 120. however efficiency also drops as current/voltage rises, so that puts the motor at somewhere around 90-110 watts.
Edit
The Bane bots motors are the smaller of the two motor spec sheets i initialy gave, verified by physical size. spec sheet here
Last edited by Hawiian Cadder : 10-02-2011 at 02:44. Reason: Clarification and update
Unread 10-02-2011, 18:34
artdutra04's Avatar
VEX Robotics Engineer
Edit
I wanted a definite answer on this, so I began searching further to try to find the original source of the BaneBot RS775-18 motors. While I don't have access to a BaneBot motor to peel the sticker off of, I did find this clear image of the 775 motors:
http://www.chiefdelphi.com/media/photos/36263
In the full-resolution version of the photo, two things are obvious: The last four numbers on the first line are "8514" and the last two letters on the second line end in "CW". On the Mabuchi website, they do sell a "775WC" motor with the part number "8514". These published specs at 18V match the published specs (for 18V operation) on BaneBots' website. The likely reason behind the letters printed on the BaneBot motors being in the wrong order are due to the fact that Manuchi is a Japanese company, and the BB motors were all made in China (possibly by a clone manufacturer).
So the Mabuchi specs list the power of the Mabuchi 8514 at peak efficiency as 273 W. The BaneBot spec sheet for their RS775-18 at 12V lists power at peak efficiency as 119.25 W. If they are the same motor, then 273W * (4/9) = 121.33 W would yield the expected power output at 12V. The expected and actual power values are only 1.7% off; if BB published their RS775-18 at 12V spec sheet from dynamometer testing, this 1.7% likely could have been due entirely to manufacturing tolerances of the 775 motors.
Thus, unless someone has dynamometer data to prove otherwise, these specs for the RS775 are accurate.
Art Dutra IV
世上无难事,只怕有心人.
Unread 10-02-2011, 20:44
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
And following that graph, at about 40 amps, the motors put out approximately 260 Watts of power unless I've been reading it wrong all season...
Unread 10-02-2011, 22:30
AKA: Isaak
to eliminate all of the spec sheet madness from this, i decided on a simple test, today i made a small hub that pressed onto the axle of the 775 and had a .5 inch diameter, hooked the motor directly to a battery, and was able to prevent it from spinning with no problem at all. i did the exact same thing with a 555 and have a rather nasty burn on my thumb from trying to hold the motor and failing. the rs550 is significantly more powerful than the rs775 18 volt version that came in the KOP.
edit for clarification
i let both spin up to full speed, then attempted to stop them spinning by gradualy applying pressure to the outsides of the .5 drum. both motors were mounted to a block, and that block placed in a vice, and both were running off direct connection to battery with the same length of wire.
Unread 10-02-2011, 23:10
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Wouldn't looking at he motor constant (Rpm/V) values tell you that the motors perform differently and they are two different motors with he same package.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 10-02-2011, 23:18
Imaginary Friend
AKA: Kevin Li
Team Role: Student
This isn't an accurate test of the motors power output but rather the stall torque.
Kevin Li
596 - Sciclones
Unread 10-02-2011, 23:26
things such as free speed come into play too.
you're really going to refute manufacturer provided dynamometer specs with a thumb test?
Unread 10-02-2011, 23:53
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Speaking of Mabuchi, my guess is that the BaneBots RS-775 motors are not made by them...see http://www.chiefdelphi.com/media/photos/36278 and look closely at the motor, and then at the drawing posted on Mabuchi's website. Observe the shape of the rear vent holes is different. While that's not conclusive proof of anything, it's a reason to doubt that the BB RS-775 is that particular Mabuchi model. (I've seen another pattern, with no vent holes, on some Mabuchi motors; that isn't it.)
As far as I know, none of BaneBots' KOP motors are made by Johnson or Mabuchi. The best refutation of this would be to find their logo: Johnson often stamps a "JE" mark on the front face of the motor (where the mounting screws are), and Mabuchi usually prints a stylized "M" on the label (they haven't used painted numbers on FRC motors in the past).
Unread 11-02-2011, 00:17
AKA: Isaak
if the rs550 had more torque at a higher speed doesn't that mean it has more power?
Unread 11-02-2011, 00:38
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yes but none of the specs support this and your thumb test did not appear to measure speed.
Kevin Li
596 - Sciclones
Unread 11-02-2011, 01:14
AKA: Isaak
thumb test = slowly apply load until motor stalls, rs550 gave me a burn because it didn't stall. rs775, stalled very easily. this is in contradiction to the spec sheets, and based on discrepancy between spec sheets i think teams should actually run the motors to see how much power they actual give off, we don't have a dyno, but someone who does can measure power.
Unread 11-02-2011, 01:21
This is not proof whatsoever.
I see no reason to not trust the banebots specs.
Unread 11-02-2011, 01:23
AKA: Isaak
ok, but i recommend you turn one on at the least, compare it to the RS-550.
Unread 11-02-2011, 01:27
Hawiian Cadder- It is amusing that you are continuously questioning the intelligence of Adam as well as team 33, among others. while they try to explain to you your errors.
I am pretty sure Adam has turned on one of the motors 5 weeks into build...
Unread 11-02-2011, 01:35
Also, on the "thumb test" the 775 shaft is significantly larger than the 550 shaft. You're able to get a much better grip on it, and apply more torque to it.
Not at all scientific nor conclusive.
