Go to Post You know this crazy ChiefDelphi... nothing but useless information and kids ranting about pizza. - Amanda Morrison [more]
Unread 10-02-2011, 07:02
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Re: pic: In_CIM_erator
Originally Posted by Hawiian Cadder View Post
pretty sure the 18 volt version is the same, we ran ours and found it MUCH weaker than the RS 550, if anything the 18v version should be weaker than the 12V version, the only difference is the gauge of wire.
Just curious about how you measured the power of the 775 vs the 550. Did you use a dynamometer? Or did you use the motors in a lifting application with a gearbox? Did you compare the work done over time?
The only info I have to go on is the motor curve provided by FRC, and the data sheet on the Banebots website. If you look at the data for the 18V motor, it maps pretty well to the FRC motor curve when run at 12V instead of 18V. I have to believe the FRC motor curve since we based our design on that. We won't know until we get our gearboxes, maybe next week.
Former Mentor Team 1771
Former mentor Team 4509
Unread 10-02-2011, 07:59
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
I can tell you that the RS775s are much closer to the CIM's max power than to the RS550's. We had been using 6 CIMs in our drive prior to receiving our CIM-U-LATORs, and the pushing power and acceleration with 2 CIMs replaced by RS775s are pretty close to identical.
Unread 10-02-2011, 08:03
The 18v RS775s at 12v are not "a measly 70 watts" - Banebot's spec sheet even says otherwise (just not FIRST's, which is wrong).
Hawaiian CADer, I've corrected you on this at least 3 times - for the sake of other teams PLEASE do not post things you don't KNOW to be true as fact, repeatedly, lest you cost someone valuable time in their season.
Be aware that Max Efficiency is different than Max Power.
Unread 10-02-2011, 08:11
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The Motor Curves document on the Kit of Parts website has been updated and contains the proper curve for the RS775-18V scaled down to 12V.
