Go to Post The robot uprising is coming for your chairs first, people. - bobbysq [more]
Unread 11-02-2011, 01:23
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Re: pic: In_CIM_erator
This is not proof whatsoever.
I see no reason to not trust the banebots specs.
ok, but i recommend you turn one on at the least, compare it to the RS-550.
Unread 11-02-2011, 01:27
Hawiian Cadder- It is amusing that you are continuously questioning the intelligence of Adam as well as team 33, among others. while they try to explain to you your errors.
I am pretty sure Adam has turned on one of the motors 5 weeks into build...
Unread 11-02-2011, 01:35
Also, on the "thumb test" the 775 shaft is significantly larger than the 550 shaft. You're able to get a much better grip on it, and apply more torque to it.
Not at all scientific nor conclusive.
Unread 11-02-2011, 01:45
AKA: Isaak
i made a hub out of delrin which press fit onto the rs 775 axle, on the other side it pressed onto the rs550 axle, they were both the same delrin drum which was tested.
Unread 11-02-2011, 01:46
I got a test for ya, a good ol drag race.
Lock the shafts of the two motors together, and run them opposite directions. Whichever doesn't die is the winner!
Unread 11-02-2011, 01:58
AKA: Isaak
i was planning on making my delrin hub into a pulley tomorrow and see which motor will lift a little weight the fastest, we are not using either of the kit motors either so i may try a drag race, that will likely fry one or both of the motors though.
Unread 11-02-2011, 02:07
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
You should do a series of weights until you reach stall that way you can find peak power. You should also use a power supply to control the voltage if possible.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-02-2011, 00:30
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We engineered a component on our robot using the R775. We knew the weight, and using the calculated power of the R775 we figured it would take: 0.8 seconds to traverse the distance we needed. It performed exactly as it was engineered to, and the R775 provided the exact amount of power that it was supposed to.
I have absolutely no reason to doubt the manufacturer's specifications on these motors. They appear to be correct.
Unread 15-03-2011, 17:16
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Just discovered this thread. From the vantage point of a month later, I suppose it is possible that Hawiian Cadder was using a defective RS775. Do you still have that motor? Do you have another RS775 you could compare it to with your "thumb test"?
A few additional remarks. Peak output power occurs at half free speed, not at stall (post #42), and not at the intersection of the torque and speed curves (unless the graph is scaled to make it so) (post #17). Kv (rpm/sec) is the velocity constant, not the motor constant. Motor constant is Km which is (stall torque)/sqrt(input watts at stall) (post #27).
Unread 16-03-2011, 01:16
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Another thing just take a look at the motors. I know this is a tad unscientific but doesn't a bigger motor generally = more power? Plus ask yourself if a manufacturer made a smaller lighter motor that was more powerful than a bigger heavier motor why would they make the bigger motor in the first place? So why is it not so off base to conclude that the RS 775 18v is more powerful than the RS 550 motor? Especially when the manufacturer's specs back up this idea.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 16-03-2011, 01:20
EricH EricH is offline
Bigger motors only have more power if they aren't case shorted half the time or more.
Guess which motor has a tendency to have a case short?
Unread 16-03-2011, 02:58
How does that add to the discussion about the 775's peak power?
The 550s have other reliability issues, just more obvious and less damning (i.e. trying to stall them will quickly result in smoke, while the 775s can take more abuse. when the case isn't shorted.)
Unread 11-02-2011, 02:02
Andy A. Andy A. is offline
Getting old
FRC #0095
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
95 used the banebots published spec sheet to design a shoulder joint. It is operating as intended, which I would not expect to be the case if the actual motor performance and the specified performance differed by such a wide margin. Given the frictional loses we're undoubtly encountering it's a little surprising that it's performing as well as it is, truth be told. We were conservative and planned on using two of these motors ganged together, but are finding out it operates just fine on one. We'll likely use the second anyways but I wouldn't be surprised to find out the motor is operating a bit above the projected rating.
In fact, not only is it operating spot on at the design speed, it is holding level a pretty substantial arm for ~10 seconds (stalled at about 15 amps maybe) with no apparent heat issues. I'm petrified of holding any longer then that right now, but I suspect it could do it. That places it well above the FP motor in my book on the size/weight/power/reliability value matrix.
Whatever the actual performance is it's way closer to the banebots published spec then it is to 70 watts.
