Go to Post Ancient doesn't necessarily mean bad, but ancient things do fall out of use, otherwise I'd be tapping this out in morse code or writing it in Latin. - Greg McKaskle [more]
Unread 11-02-2011, 08:13
Mike Schreiber's Avatar
FRC #0067 (The HOT Team)
pic: FP Gearbox Hubs
Unread 11-02-2011, 08:14
Re: pic: FP Gearbox Hubs
If you had posted this two weeks ago we'd have a functional arm by now
Great part - I love it! That 3450 sounds like they're doing great.
Unread 11-02-2011, 08:24
Data Nerd
FRC #0079
As pictured this part weighs ~.5 lbs though.
We would be in a lot of trouble if it weren't for the generous machining support we have received from local teams like 2337 and 68. I can't tell you how many hours of lathe time 2337 has donated.
Chris, if we had known it two weeks ago we would have been very happy, I'll get a picture and show you our iterations of ideas.
Unread 11-02-2011, 11:17
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Last week we used Rice University's 3D printer to make an adapter that fits nicely into the fins of the gearbox and adapts it to a 1/2" hex shaft like yours. I'll try to get some pictures of our winch assembly tonight.
I'm still slightly worried that the part won't be strong enough so we may try to make one like yours for backup.
Unread 11-02-2011, 11:29
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Not to go off topic here, but I've made FP hubs in a 3D Printer (Dimension SST1200) and they tend to split in between layers. When printing, insure that your axle is not on the machines Z axis or they're extremely prone to splitting in between layers under torque. If your printer isn't a layer type then you should be fine.
-Dustin Benedict
Unread 11-02-2011, 15:13
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
I'd be a bit concerned myself as well. It really depends on orientation of the hub during printing, with what machine, and material.
Since you said you would post photos of your "winch" assembly that makes me even more concerned...
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
