Re: pic: Banebot P60 Failure
Our failure point was those spring pins getting torqued off the flats also. All the gears are fine. We removed the spring pins and drilled out the pin holes for larger pins going deeper into the face plate. Then put divots where the pins interface the flats for the pins to seat in. Seems better than new this way and running good now.
