Go to Post So just stamp "GEEK" on my forehead - dlavery [more]
Unread 14-02-2011, 17:17
J_Miles's Avatar
J_Miles J_Miles is offline
FiM Referee
AKA: Jared Miles
no team (EngiNERDs)
J_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to behold
Re: pic: Robot is coming together....
Originally Posted by Bob Steele View Post
If your intent is to make a structure with the minimum weight and a definable way of transfering energy (either from gravity or collision or something else..) then triangles are the way to go.
For sure. Generally when we lighten our robot, we arbitrarily take out material in areas of low stress, but when we want to eliminate serious amounts of material and retain a LOT of strength, we have some of our more mathematically-inclined students and our resident structural engineer go to work. For example, our lifter from last year had to be strong enough to support 450 pounds of load (which it never used, sadly), yet still needed to be strong, so we did all of the stress analysis and turned the main support member into a truss, which I guess is two adjacent triangles.
Unread 14-02-2011, 23:26
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
As an old-time robot inspector, I think you need to check the bumper rules. It doesn't look to me as if your numbers meet the 3/4 in. stroke requiremtent. Hate to be the bearer of bad news, but though you might want to know before you hit your first regional!
