Re: pic: Building blocks of a 1 lb shifting transmission
For reference our 3d printed ABS plastic ball lock transmission (as shown here less CIM) is 26 ounces.
The only metal parts are two 1" bearings, three thrust bearings, air cylinder, a few bolts and a precision 1/4" shaft. http://www.chiefdelphi.com/media/photos/36161 It is possible to make a 1 pound transmission, but will it hold up? ![]() Are you direct driving a wheel? What are you using to shift? Last edited by team222badbrad : 15-02-2011 at 17:46. |
Ha wow leave it to CD to take everything literally. It will probably turn out closer to 1.5lbs per transmission. This was really just supposed to show off some cool gears that will save a decent amount of weight over their steel counterparts
They are 7068 aluminum hobbed and anodized. These should also hopefully be available for purchase by next season for anyone interested in saving a big chunk of weight and higher quality over andymark gears. Cory, had we been investing our time into making these versus just machining steel gears we would have gone the steel route as well but given the choice to do both without any extra resource allocation we went with the aluminum. The only downfall was the wait (no pun intended) but that was remedied by running steal gears in the interim Last edited by sdcantrell56 : 15-02-2011 at 17:53. |
those look awesome! (This team is definitely gonna win Einstein guys. no doubt about it)
so have you weighed the finished trans yet? I would love to see the final weight!
