Go to Post Coming soon to an Earth near you; an Australian team (or 2). Stay tuned. - Elgin Clock [more]
Unread 21-02-2011, 19:13
DFZXA DFZXA is offline
FRC #3055 (Furious George)
DFZXA is infamous around these parts
Driver station reads 17 volts????
When I look at the driver station it reads 17.7 as the voltage??? It doesn't drop at all it just stays right at 17.7
Unread 21-02-2011, 19:43
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Driver station reads 17 volts????
Either you have it hooked up wrong, or you have the Battery of the Gods. Probably filled with Mountain Dew...
Unread 21-02-2011, 19:45
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
I admire your battery.
Attending: MN Duluth Regional
Unread 21-02-2011, 19:56
MrForbes MrForbes is offline
What does your handheld digital volt meter say is on the PD board main terminals?
Unread 21-02-2011, 20:18
I hooked it up to a power supply and it reads 9 volts (that's what I set the power supply to) but the driver station still says 17.7 and won't move from that
Unread 21-02-2011, 20:20
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
9 volts is awful low. could it be a bug with a battery with really low voltage?
Unread 21-02-2011, 20:22
No I set the power supply to 9.5 just to be safe cause I don't like accidently setting it to high (it has a very sensitive dial) so setting it to 10 made the pdb 10 too
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
This made me laugh so hard...
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 21-02-2011, 20:31
seannoseworthy's Avatar
seannoseworthy seannoseworthy is offline
FRC #2200 (MMRambotics)
seannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to beholdseannoseworthy is a splendid one to behold
Send a message via MSN to seannoseworthy
Do you have the jumper on the breakout installed correctly?
Unread 21-02-2011, 20:44
Well the wire going to the breakout is reading 24 volts off a voltimeter and I haven't touched the jumper since last year.
Unread 21-02-2011, 20:47
WPI Freshman
AKA: Alex
Wow.... Did you hook the analog breakout board up to the 24V boost on the PD, or did you do it the right way and connect it to one of the standard 12V outlets?
Unread 21-02-2011, 20:51
Sorry we had a 24AC battery hooked up
Unread 21-02-2011, 21:08
AKA: Matt B
FRC #1771 (1771)
Wait, a 24V *AC* battery?
Unread 21-02-2011, 21:12
Twas only a jest. It's working now I had a loose wire and it just froze at that voltage for some reason so when I restarted the driver station it was 0 volts but all's good.
Unread 21-02-2011, 23:33
NullEntity's Avatar
NullEntity NullEntity is offline
AKA: Bryce
FRC #0093 (N.E.W. Apple Corps Robotics)
Team Role: Scout
NullEntity is an unknown quantity at this point
Should it have even been at that voltage in the first place?
FRC Team 93 Alumni
