pic: 179 Swampthing 2011
http://www.youtube.com/watch?v=oMx_S_H-a0I http://www.youtube.com/watch?v=z4KUwIJrF0c http://www.youtube.com/watch?v=bOxRFRwZ6uA http://www.youtube.com/watch?v=tuUKcLoOBb8 Last edited by Swampdude : 22-02-2011 at 00:08. Reason: adding videos |
Re: pic: 179 Swampthing 2011
The claw!?!? it doesn't move!!?!?! I LIKE IT!!!!
Wow, I am quite impressed with how effective a static gripper is. Nice job. Have you run your robot into walls, etc. to simulate active defense? Is your grip on the tube firm enough to withstand basal blows?
The claw isent completely static, there are servos mounted into the pvc with fingers that hold the tube in place. there programed to open and close on there own at certain arm positions to keep them from getting destroyed. When there closed you cant get the tube out for anything.
I hope your mini bot deployment is ok with G<22>
HOSTBOTS may not contact their ALLIANCE‟S MINIBOT while any part of it is above the DEPLOYMENT LINE. |
It is by about an inch, if they think were cutting it to close it can be lowered but it shouldn't have to be.
Has that rule been clarified? I haven't had time to look, but I could read that different ways. Seems they should put a time frame on that rule. It's stowed right at the height limit anyway.
Also, this green is slightly darker than previous robots
With respect to the deployment height, it's during deployment. Deployment starts as soon as the Minibot crosses the cylinder formed by the vertical projection of the base of the tower.
If you're stowed right at the height limit, something you should check is that the Minibot doesn't go over the line while being deployed. The line is to be treated as a plane, according to the GDC via Q&A. It doesn't look like you'll have much of a problem there, but it never hurts to check. |
#10
Thanks, that makes more sense.
#11
<G22> HOSTBOTS may not contact their ALLIANCE‟S MINIBOT while any part of it is above the DEPLOYMENT LINE. Violation: TOWER is disabled I don't see anything their about this being only during deployment. It is just in the End Game section of the manual. END GAME – the final 10 seconds of a MATCH. If I am wrong please can you link me to the Q&A that disproves me |
#12
It's in the end game section; you can only deploy during the end game. Think about it. Admittedly, you could apply it anywhere else on the field; it's just much harder to enforce away from the towers.
There are a couple of related Q&As, though they're on <G21>. http://forums.usfirst.org/showthread.php?t=16251 http://forums.usfirst.org/showthread.php?t=16981 The second one does say that <G21> and <G22> work in combination. |
#13
That really stinks for the teams without a mini bot that are in the scoring zone with a tube when the end game starts... The best example I can think of with regards to not having the minibot above that line at any point is 148. If <G22> wasn't there, their minibot could have been at the end of the drop down bridge. As long as they dropped it before they crossed over the tower base. Instead of them running the minibot forward off the bridge once its droped. (sorry swampthing this probably isn't the place for this discussion and anyway your deployment is perfectly legal)
#14
What do you mean? If you don't have a minibot aboard, you can't contact one above the deployment line. At least, it's much, much harder.
Edit: I think I see what you mean now. You're thinking, based on my post, that the only thing you can do during the end game is deploy. This was thought before TU#5 came out, too; my apologies for using the older type of wording. I should have said that the only time deployment was legal was during the end game. Last edited by EricH : 22-02-2011 at 15:42. |
#15
I like the simplicity of this year's bot 179.
It reminds me greatly of your 2005 beast not necessarily on the physical design, but on the design strategy. The minibot looks great too. -Brando |
