Go to Post wonder if the April peak for 'frisbee launcher' was from the GDC... - cbudrecki [more]
Unread 18-02-2011, 12:10
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
paper: Aluminum Falcons (FRC2168) 2011 Scouting System Ver 1.1
Up for your review and consideration is the Aluminum Falcons (FRC2168) 2011 Scouting System
It is a fairly programmed excel based system for data entry and evaluation.
Please note that it was develeped in Excel 2003.
This Thread was created automatically to discuss a document in CD-Media.
Aluminum Falcons (FRC2168) 2011 Scouting System Ver 1.1 by jwfoss
Unread 18-02-2011, 12:24
liam.larkin's Avatar
liam.larkin liam.larkin is offline
We will find a way or make one!!
FRC #0272 (Cyber Crusaders)
liam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to behold
Re: paper: Aluminum Falcons (FRC2168) 2011 Scouting System Ver 1.1
WOOOOOOOWWWW this is awesome. You should be very proud of yourself. Do I have your permission to borrow this and modify for my teams usage?????
Unread 18-02-2011, 13:00
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
Wow, very nice. Only question I have is on the "Scout Data Input" or "Printable Sheets", you have different options for combinations of tubes on the pegs....how do you record, for example, if there is a Red and White on the peg, or Blue and Blue, vs. just having a normal tube and an uber tube? Basically, how do you record if a robot scores more than one tube on a peg that is not an ubertube?
Maybe split each scoring square into two? Other than that, it looks great!
Unread 18-02-2011, 13:28
AKA: Justin Foss
Thanks for the positive comments. I am very proud of our team this year. Feel free to use the system as it is, however the code and sheets are currently locked from being modified besides the normal inputs (for use by the scouts).
The difference in the sheets is for ease of the scouts filling them out. In terms of have multiple tubes on a single peg (one of them not being an ubertube) I am under the assumption that this is not likely to happen as only the "outtermost" tube counts for points. <G63> If two GAME PIECES are HANGING from a single SCORING PEG, the outermost GAME PIECE will be counted for scoring purposes. If we see this happening at regionals the code will be modified to monitor that as well.
Thanks again for taking a look at our system, we appreciate the comments!
Unread 18-02-2011, 13:36
ahollenbach ahollenbach is offline
AKA: Andrew
FRC #0103 (Cybersonics)
ahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to all
That's a phenomenal system - it not only looks great, but you definitely will have sound and comprehensive data at the end of qualifications.
Good work!
Unread 18-02-2011, 13:44
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
This is impressive.
Have you practiced how long it will take to enter the data after every match? I suspect you will need to have 1 dedicated scout that just enters data as it will take longer than the 3-5 minutes to input everything in between matches. We only input some of the information that we collect into excel, so we can have an extra scout watch matches.
Two suggestions:
I would add a comment section on the printable form. I don't want to think of the information we would have lost if we didn't have a comment section.
Also, perhaps you could make the printable sheet more printer friendly. Not just the colors but the grey will take a lot of ink (and time).
Unread 22-02-2011, 08:18
AKA: Justin Foss
Thanks for the suggestions XaulZan11, I agree on the "printability" of the sheets, thanks for catching that. I'm looking into the comment section, however I am interested to see how observant our scouts will be without direct things to look for. The data in the system is currently not very subjective.
On a side note, 80+ downloads and very few comments?
Unread 22-02-2011, 08:25
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
Rookie Year: 1997
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
WOW! This looks awesome. Phenomenal work. I will definitely be sharing this and may use it fully, or use it as a template for another scout system. Once again, great work and good luck in the 2011 season.
Cass
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
[/size]
Unread 23-02-2011, 13:58
Quijas's Avatar
Quijas Quijas is offline
AKA: Jose Quijas
FRC #0597 (Wolverines)
Quijas will become famous soon enough
Send a message via MSN to Quijas
wow, This is great thanks for the upload.
lots of teams will appreciate this.
Student (597) 2005-2007
Mentor (597) 2007-present
Mentor (5089 and 4964) 2014-present
Unread 23-02-2011, 21:53
Alright...after looking at the latest version (1.3) I noticed just a couple thing
1 )Like Jstack14 mentions below, all teams show that it recieves 1 penalty for every match played on the "Data Analysis" tab, regardless if you said they actually got one or not.
2) Would it be possible to add a box showing the autonomous score percentage (# scores vs. # matches played/attempts) on the "Team Template" tab next to the graphs in a big font?
Also, now that I think about it, I feel like the graphs would be more useful if they were averages, rather than just displaying historical data, or at least a seperate box next to the graphs showing these averages. The historical data can be seen under the graphs at the individual match data. When glancing quickly at the "Team Template" Im looking for quick information, and not so much what happened in each individual match.
3) Also, I could not get the sorting from High to Low, or Low to High working on the "Pick List" or "Data Analysis" tabs, specifically for the average and Qual rank columns
If these things could get fixed/added and reuploaded it would be great!
Unread 23-02-2011, 22:18
Jstack14 Jstack14 is offline
Jstack14 is infamous around these parts
Incredible! Maybe i am missing it but is there a way to delete an input? If not that would be a useful feature incase someone inacuratley puts in data and needs to change it.
Unread 23-02-2011, 22:22
another quick change, it is adding 1 penalty for ever match no matter what. Can you edit that?
Unread 24-02-2011, 08:25
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Foss,
This looks pretty nice. Great job. After work I'll take a closer look at it. It reminds me of what I have started and haven't finished... maybe I don't have to finish mine now
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 24-02-2011, 11:19
BX MARK's Avatar
BX MARK BX MARK is offline
AKA: Mark
FRC #3542 (S.P.E.E.D.)
BX MARK will become famous soon enoughBX MARK will become famous soon enough
I also noticed that it was adding a penalty point even if there was none. A simple solution was to remove the option of "No" under the penalty drop down box. I made it so my scouters can only select yes. If there are no penalties the box just stays blank.
2011-2012 Team 3542 S.P.E.E.D.
2010/2011Bedford Express Captain
Unread 24-02-2011, 13:09
AKA: Justin Foss
Update 1.4
Corrected Various Programming Issues.
Thanks again for positive comments and suggestions. Sorry we cannot add or change everything suggested but we will strive to fix things are not working correctly.
For those of you currently planning to use our system, please post here as we would love to see the number of teams using it.
Also, if you are going to be at BAE, SBPLI, WPI, or CT I'd love to stop by and talk to you about it.
FRC2168 will be at WPI and CT.
