Go to Post I applaud teams that make signs of all kinds - giant numbers, large banners, humongous heads. It's all good. - Ryan Dognaux [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 28-02-2011, 17:26
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: Team 148 - 2011 - Raptor
While I think its cool shifting wheels instead of shifting gears, I don't really see how it is simpler at all. A transmission is quite compact and requires a small amount of force to shift versus needing enough force to lift the robot to drop down the traction wheels. The only potential benefit I see of this system without the perpendicular omni wheel is the ability to change the center of rotation although the benefit of that wouldn't necessarily be worth the added weight of the system.
JVN given that you ended up taking out the 5th omni wheel would you stick with this drive if you could do it over or go with a more conventional 6 or 8wd with shifting transmission?
