Go to Post A coin flip is a wonderful thing. Not because it makes the decision for you, but because when the coin is in the air, you realize what you really want. - rtfgnow [more]
Unread 13-03-2011, 01:49
Re: pic: 2791 Starting Configuration
One positive this weekend: We weighed this robot, with a claw made of round 1/8" wall aluminium instead of the wood used here, along with a few other weight increasing parts.
The robot weighed only 100 pounds. 20 pounds under, and everything on this bot is 1/8" wall.
Minimalism is beautiful.
One thing that turned out to be no problem was arm retraction. We took a full speed hit to the end of the arm without a scratch. The PVC's give was perfect for this. All we had to do was drive with the arm up in the air to score, and with our freakishly low CG it was very easy to do.
We had a lot of bad luck at WPI, but at least some of the cool stuff worked the way we wanted it to.
