Go to Post Beatings will continue until morale improves! - DampRobot [more]
Unread 14-03-2011, 19:03
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: pic: 3729's minibot
From TU #12
A note about “light switches” permitted on the MINIBOT:
We have previously stated in the Q&A that “light switches” are only “light switches” if they are commonly used in a wall mounting box. Rule R92-N, however, uses the language “common household light switches”; which can have a much broader interpretation. Given the discrepancy in specificity between R92 and the Q&A statements, we defer to the manual. Therefore, “light switches” permitted on the MINIBOT are not confined to those used in wall mounting boxes; anything sold as a “light switch” for household use is allowed. The Q&A answers will be revised.
Lamp switch = light switch and yes you can buy them at Home Depot with the rest of the "light switches"
