Go to Post "Oh, I get why we have Toy Story band-aids!!! The character Woody, and then in FIRST, we have Woodie Flowers. Woody = Woodie? I get it! I GET IT! - Millory [more]
Unread 14-03-2011, 10:22
John G John G is offline
FRC #0399 (Eagle Robotics)
John G is on a distinguished road
pic: Team 399's arm after the SD finals match 1.
Unread 14-03-2011, 10:26
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: pic: Team 399's arm after the SD finals match 1.
Any thoughts on what caused the failure?
I watched the claw appear to twist while you guys were near the Blue Alliance pegs attempting to hang. I thought it looked odd, guess it was really the arm that was twisting. Then it was, OMG their arm came off!
Sorry that had to happen.
As soon as I saw your alliance with 1504, I leaned over to my neighbor and said "It will be them and #1 alliance in the finals". I knew your alliance was going to be strong, too bad it had to end like it did.
Good luck in the rest of your competitions!
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 14-03-2011, 11:04
artdutra04's Avatar
VEX Robotics Engineer
Looks stressful.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-03-2011, 11:05
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Is it really surprising that the arm failed given the quite drastic lightening pattern used on the arm?
Definitely a bummer but maybe side on the side of slightly overbuilt versus one hit away from total failure. Also maybe look into fiberglass to save weight without having to be cheeseholed
Unread 14-03-2011, 11:07
MrForbes MrForbes is online now
Wow, that's a bummer. It's also a tough way to learn about why tubes should be left tubular, and not cut away....
Unread 14-03-2011, 14:15
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
when i first saw this i thought it was wood. bummer but for replacement thinner walls usually make for a tougher/weight ratio than thick walls pocketed.
Unread 14-03-2011, 14:38
Is that break also further up the arm? (closer to the pivot)
If you want to pocket, use a smaller diameter and also just use regular holes instead of large slots like this one.
Unread 14-03-2011, 14:45
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
From what I saw in the video of Final 1, it looks like the arm broke close to the pivot point, probably within 3" or so. (But I could be wrong.)
-Dustin Benedict
Unread 14-03-2011, 15:25
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
That's what it looked like from the stands, the break was just beyond the pivot point.
Unread 14-03-2011, 15:48
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Talking Re: pic: Team 399's arm after the SD finals match 1.
Thanks for a great alliance guys. Nice being with 399 and 1540 as well as 294 Good luck at your next regional
Unread 14-03-2011, 16:30
robodude03's Avatar
robodude03 robodude03 is offline
AKA: Rene Haro
FRC #1538 (The Holy Cows)
Team Role: Tactician
robodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond reputerobodude03 has a reputation beyond repute
The break was about 4" down from the pivot point. The initial end effector (pincher claw) was much lighter before weighing approximately 2lbs. Put a 6lbs roller claw out there (including the pocketing) and you can easily tell why this arm broke off. The stress by the end of the competition was too much.
I can assure you that our new arm will have much less holes by the time we go to LA. It's a painful lesson to learn, particularly in the finals, but one that we will remember.
Team 1538 - The Holy Cows
2015 Championships - Quality Award sponsored by Motorola
2014 Championships - Media and Technology Innovation Award
2013 Championships - Chairmain's Award Winner and Newton Finalists w/ 217 & 1986
2013 to Present - 1538 Mentor (Digital Media/Strategy)
2004 to 2012 - 399 Mentor/Coach
2000 to 2004 - 399 Driver
Unread 14-03-2011, 18:24
r2davis2's Avatar
r2davis2 r2davis2 is offline
no team (Purdue FIRST Program)
r2davis2 is an unknown quantity at this point
That is terrible, I only saw it from the stands, and it looked pretty bad even from up there. Hopefully you guys can get that fixed because that was one great robot.
I do have to thank you very much for allowing us to be substituted into your alliance
294 - Beach Cities Robotics(2009-2011)
- 2010 World Champions(thanks 67 and 177)
LA regional 2012 Field Reset
Boilermaker Regional 2013 Referee
Unread 14-03-2011, 21:28
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
It was painful to watch, the arm broken inches away from the pivot, the rollers of the claw causing it to drive around away from the frame, and then to see your robot start smoking when attempting to deploy, all in the finals.
What are the specs on the material you used for your arm?
hope to see you guys up and running around stronger than before! see you in LA!
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 14-03-2011, 21:36
I doubt the arm failed because of its material properties but rather the lightening pattern. Strength of cross section is much more important than material choice.
An 1/8" version of this arm would be substantially stronger if it were 1/16" and left unlightened.
Unread 15-03-2011, 08:43
thefro526's Avatar
Mentor for Hire.
An unlighted 1/16" version would probably be stronger, but the question is, can you get the correct tubing size in 1/16" wall? I've been looking for tubing for our arm redesign, and usually only 1x1 and .75 x .75 tube come in a 1/16" wall.
-Dustin Benedict
