Go to Post A shaft that yielded is just as useless as a shaft that broke. - Chris is me [more]
Unread 17-03-2011, 22:45
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: pic: Seattle Cascade tubes.
Originally Posted by Francis-134 View Post
FIRST does have some control, specifically the templates they send with every field. If the tubes are inflated to the template, they will at the very least be consistent.
At WPI, we inflated them until the tube touched both sides of the template, then stopped.
The problem is that the instructions/method for using the template doesn't seem to be consistent across events. I have heard a number of reports from multiple regionals, both on CD and from other contacts of tubes being inflated outside the template and then jammed into the template to prove compliance.
