Go to Post I firmly believe that - those [GDC] committee members I have met, even briefly, certainly have a passion for what they are doing and want to give teams and students the best possible experiences. - GaryVoshol [more]
Unread 20-03-2011, 13:46
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: MINIBOT acceleration solution
Originally Posted by boomergeek View Post
I used 7400 for freewheel speed based on Richard's dynamometer results and then I adjusted the friction number until it approximately matches the video evidence of our minibot...
it predicts 2 lbs of friction!!
Did you use .09 or .094 for the stall torque?
If you use .094 then a straight line from 7400 free rpm to .094 Nm stall will give a max power of 18.2 watts. I think that's a bit optimistic.
If you use .09 then it's 17.4 watts, which matches the upper curve in Richard's data.
Since it appears there may be some significant variation in the motors, I selected freeSpeed and stallTorque values for the spreadsheet which give 16.8 watts, to make the numbers a bit more conservative. But of course YMMV.
