Originally Posted by thefro526
R47-A covers the removal of the pinion - if you consider the pinion to be a part of the motor.
Personally, I don't believe that the Pinion is an "integral part" of the motor, since removing it doesn't change how the motor works...
I read <R47A> several times, too. I think that the modifications allowed by it relate to the attachment of the motor to the robot or the shaft attaching to actuated part. So if the pinion is part of the motor shaft then, OK by r47a. In the case of the Tetrix motor, there is a bracket to which the gearbox is attached. Part of the gearbox? or motor? Maybe it doesn't matter, since modification of it is allowed to change attachment of the motor to the robot. I don't think that the pinion is part of the attachment of the motor to the robot, but it is part of the attachment to the actuated part.
The blue section below <R47> outlines the intent of forbidding structural modification. I'm really not trying to be pedantic, but if removing the pinion didn't change how the motor "works", then why do it? weight reduction? That is my opinion of course, and we all know how influential personal opinions are at the inspection station, right?
