Go to Post 2011. Tried swerve. Didn't move for 1.5 regionals. - cadandcookies [more]
Unread 18-02-2011, 14:28
MattC9's Avatar
MattC9 MattC9 is offline
pic: Sprocket legality?
Unread 18-02-2011, 14:29
Re: pic: Sprocket legality?
Floating tension sprockets are perfectly legal. Might want to support the end of that shaft by the way.
What could be illegal about that sprocket?
Unread 18-02-2011, 14:39
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Looks like they've got the holes to mount the bearing block...
And teams have used floating idlers for years, they work great.
-Dustin Benedict
Unread 18-02-2011, 15:19
For anyone who is interested in getting sprocket center distances just right, I've had fair luck using the numbers from this calculator http://www.team-moon.com/index.php/calculators/chain/, at least for #35.
Unread 18-02-2011, 15:27
dtengineering's Avatar
AKA: Jason Brett
The sprocket might be fine, but in this particular photo I would have some very real safety concerns about things (such as human hands) getting caught in the chain.
I'm sure that a guard for the chain and/or a robot exterior that inhibits access have been removed for clarity, but just a friendly reminder that just because a part is legal, the application of that part will not neccesarily pass tech if it is deemed to be unsafe.
Jason
Unread 18-02-2011, 15:32
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'd be more worried about that P60's internals.
Unread 18-02-2011, 15:46
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I would, too.
From the Banebots site: "We recommend maximum torque not exceed 35 ft-lb for all P60 Series Gearboxes. It is possible to mount motors that will exceed this in higher gear reductions. Higher reduction gearboxes should be utilized primarily for speed reduction. Designs utilizing a P60 gearbox / motor combination that will exceed 35 ft-lb should include a method of limiting torque to prevent damage to the gearbox."
I can't see the whole arm in this picture. If it swings past the top, shock load through a tight chain just might cause the hole in the P60's output carrier plate to deform from its nice double D shape into an ugly bow tie.
Richard Wallace
since 2003
Unread 18-02-2011, 16:34
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
You should be able to run these gearboxes like this ok, just scoot the gearbox over and run that sprocket right next to the face. That way, almost all of the load is torsional with a little bit of shear and hardly any bending. Four more holes and you're running like a champ!
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 19-02-2011, 01:41
MattC9's Avatar
Thanks for all the replys, they have all been great. I took this picture right after we put the sprocket in and now it does have a 2nd point of contact. Our arm is a 4 bar linkage with a 30in "finger" on the end of it and it weighs about 35lb, so I think our gear box should be fine. Our main mentor loved the idea of putting a guard on the chain, that will come out sometime tomorrow.
Unread 19-02-2011, 02:07
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
a 35 lbs arm that is longer than a foot to its center of mass will be a problem for that bane bots. i would recommend some more reduction. ex, our wrist is similar, but weighs 15 lbs and the torque of the the gear setup powering it is well over 130 ft lbs.
Unread 21-02-2011, 00:29
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
I would be careful on relying on the p60 gear box for that application. You said your arm is 35 pounds, well if that is true any time the center mass of the arm is greater than 1 foot away from your pivot point. The gear box is at a significant risk of stripping its inner gears.
Torque= Force X Distance
35 ft-lb=35lb X 1ft
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 22-03-2011, 12:46
MattC9's Avatar
Ok, quick update we kept the whole arm as our 30lbs with holding allowance, and it only weighed 22lbs!! Including the supports. So the p-60's were only lifting about 20lbs.
Unread 22-03-2011, 18:32
Gdeaver Gdeaver is offline
FRC #1640
I wonder if the banebot people monitor this forum or is it too much for them to endure.
Unread 22-03-2011, 21:17
DonRotolo's Avatar
Back to humble
FRC #0832
Please let us know here how that gearbox held up in competition, we're interested.
